Post by nccamper on May 17, 2015 12:12:37 GMT -8
Okay, this has all sorts of design issues. But we're going away tomorrow and they are forecasting 90 degrees in the mountians... in May. Eventually I plan to overhaul this camper and put in a portable unit that will vent out the old roof vent. Forgive me for this Red Neck contraption, but it works. In about two hours I pulled this together with an a/c we had in the shed, three flanges left over from a plumbing job, dryer ducts and junk I had laying around. Here are the problems: The air does not recirculate, so it is running full blast while on. The campground electric bill may be ugly. A member did something like this last year and ran the return through a separate duct. Not something I can do quickly but it would solve the "return" issue. The camper gets down to 50 degrees if I let it run. Bring a comforter for the bed or run the cord in a way you can turn it off easily. And I need to shield it with a small tent-like cover if it rains. Total cost if you had the a/c and bought everything else? Around $30 at Home Depot. Laugh if you want, two months from now in the heat of the summer you'll be revisiting this thread.
Post by vintagebruce on May 17, 2015 16:44:36 GMT -8
It has to be the perfect solution. You used Red Neck in your post!!
Post by nccamper on May 17, 2015 18:21:22 GMT -8
It has to be the perfect solution. You used Red Neck in your post!! When you live in the South and a heatwave is coming the day before you leave, you grasp at any solution. If I leave it on high for an hour the camper would turn into a snow globe. It made me laugh while I was testing it so I thought I'd share it. When I get back I'm shopping for a portable unit I can install in the closet.
Post by turbodaddy on May 18, 2015 2:12:11 GMT -8
Very COOL!!!
