nickp178
Post by nickp178 on May 1, 2015 11:47:17 GMT -8
So I finally got around to checking out the Norcold fridge in our Swiss Colony, found that it works great on electricity, so I moved on to propane. After reinstalling the fridge after cleaning/painting/modifying (see my thread in appliances) I tried the propane. Pilot light went up ok, and burner kicked in after only about 30 seconds of holding the thermocouple button. While watching the burner run, I noticed the smell of unburned propane. I sprayed all of the joints on the controls and found the combination gas valve/electric switch bubbling slightly arond the valve. I shut the gas tanks off and disassembled the shut off for the fridge. I found that the valve is a tapered cone style that uses a spring to keep it seated, but has no mechanical seals, IE: o-rings. A little more research taught me that these valves use a special graphite based grease to create the seal, mine being dried and mostly pushed out the ends of the cones. I found plenty of suppliers online, but being impatient wanted to find it locally. I had checked every plumbing/heating, refrigeration and appliance supplyhouse in town and most of the guys looked at me like I had two heads. I had even called two different friends who are plumbing/heating contractors and struck out. Finally deciced to stop by the local gas utility service headquarters, and finally made some progress. After explaining the situation, and hoping to get just a little dollop of grease, one of the guys grabbed a tube of it off the shelf and handed it to me, no charge. Same stuff I had seen online in my searching, BASO brand "Gas Valve Grease", it appears that the current formulation is Moly based as opposed to graphite. Cleaned and re-greased the valve, works beautifully, no leaks.
Cheers, Nick
nickp178
Post by nickp178 on May 6, 2015 16:48:15 GMT -8
nickp178
Post by nickp178 on May 6, 2015 16:48:59 GMT -8
nickp178
Post by nickp178 on May 6, 2015 16:50:19 GMT -8
nickp178
Post by nickp178 on May 6, 2015 16:51:05 GMT -8
nickp178
Post by nickp178 on May 6, 2015 17:17:44 GMT -8
As you can see, what little grease that was left had migrated out of the ends of the valve and also into the bore passage. The D-shaped washer is the eccentric that engages/disengages the electricity when you turn the gas valve.
Cheers, Nick
RinTin
Post by RinTin on May 7, 2015 6:37:09 GMT -8
Your refer refurbish is one of the neatest projects going right now. It's great to see how you've dug in and are finding solutions. I have a great appreciation for simple, easy to service mechanical mechanisms. Thanks for sharing!!
Post by cowcharge on May 11, 2015 11:23:27 GMT -8
I wish my old fridge had been salvageable... Sigh. But it gave me an ammonia surprise party when I opened the door.
If it's "moly"-based, and I'm assuming that is short for "moly-d", or molybdenum disulfide, then regular old silver anti-seize should work as well (I'd double check the ingredients though). Is it silver?
nickp178
Post by nickp178 on May 18, 2015 6:56:01 GMT -8
Thanks, RinTin, I'm not afraid to dig in! Cowcharge, this stuff is actually a dark gray color, very sticky and thick. I wouldn't trust anti-seize as it has bigger particles in it.
