admbvi
Post by admbvi on Mar 30, 2015 16:11:18 GMT -8
Hello, I inherited a Progressive Dynamics Distribution Panel (30amp chord) charger/converter and need some help. I called PD and they do not support discontinued products and the company has changed hands many times so no experienced folks are there any longer. I am looking to find out what Model I have (it is not shown on the panel) and then how can I install/wire it? It has a Shore/Main breaker panel on left with one 30A Main, twin 15/20 and a 15 GFI breaker, A Generator breaker panel on Right with a 20A with a black wire coming from the bottom? and a 15A breaker. It then has the 12V fuse panel on the far right of the panel. I have pics here
postimg.org/gallery/1y81hx44u/
Post by vikx on Mar 30, 2015 22:20:10 GMT -8
It looks to be a motor home unit. Is there a model number?? The generator portion could be bypassed, very few of our little trailers need that. Basically, the first section is the 110 power supply. It also supplies the converter for the 12 volt section. Battery charge wiring goes into the 12 volt section as well. As to the "how" of wiring this unit, I'm not sure. The photos are good but a little small for these weary eyes. I would ask around at a lot with older motor homes. Look for the grey hair on the lot... Also, a search for an owner's or installation manual may help. Here's one on a "charge sentinel" www.progressivedyn.com/pdfs/PDI%20Service%20Manual%20710778.pdf
