Post by Teachndad on Jan 31, 2015 6:49:56 GMT -8
Hi,
Andy has carried with him a Carlson floor heater. I don't know if it was original. I recently removed it. I would like to test it to see if it works as well as check for CO2 build up. I do have and use a CO2 detector with my 85 pop up.
How would I go about testing it? I have started clearing out the dirt and spider webs. There is an elbow connection coming out the bottom where the gas line goes connects. Any simple ways to hook it up to a large or even small propane tank.
I like the idea of having heat in the trailer when dry camping which is most of the camping we do. We have seldom camped with shore electricity. My 85 pop up has a propane fan driven heater which we have enjoyed when camping during cold nights in Mammoth and at Joshua Tree Monument at Thanksgiving when it gets down to 32" degrees in the trailer. We would just run that in the evenings and turn it off when sleeping.
I have a Coleman Procat heater that I could use instead of a floor heater, but when the darn thing burns, it emits a chemical smell. I have run it about 10 times in that last 8 years and the smell comes back every time. I don't really like using it because of the smell.
Thanks
Post by Ten on Jan 31, 2015 15:03:09 GMT -8
Rod, I have pulled everything outside to test, because I am afraid of something going tragically wrong. So far it hasn't happened, but I would have really hated to lose the trailer to a fire before I even have all the mice out. Wait...then again....I do hate mice.... I found an old gas grill that someone was scrapping, and cut the regulator hose off from the burner control. Then I took a piece of copper line from one of the trailers, which had the flare end for the appliance hookups, and cut the line off. The flare size has been the same on all of the appliances I have tested. Just slide the copper inside the rubber hose and clamp it with a hose clamp. The regulator can hook up to a gas grill (20-lb) tank, and you are good to go.
Post by Teachndad on Jan 31, 2015 18:47:21 GMT -8
Hi Ten, Great resourcefulness on your part! I was going to test outside, always a good idea with these relics. Unfortunately, I went to work on it today, and I couldn't even turn the pilot, on, off knob. The knob stem goes down just about 1/8" and then refuses to turn. I tried some lubrication with no results. I took it apart as far as I could get access and then just decided it was time to give up. I think it's time for the curb people to pick it up. Looks like I am going to have to plug the whole. On a good note, we now have a searchable thread that shows how to test a heater. Cheers Rod
