man314
1964 Shasta 16-SC
Post by man314 on Jan 14, 2015 17:29:30 GMT -8
Any way of fixing a wheel well that is split like this without taking to a welder? I hear they are spendy. PO just duct taped it. Anyone well replacement wheel wells? Might be cheaper than welder fees. Plus, it's pretty bent up. Looks like the PO got a Honey Badger trapped under the sink.
Post by nccamper on Jan 14, 2015 22:03:13 GMT -8
I saw a wheel well that a previous owner just bent the seams tightly together and used a metal strap around the corner to secure it. (Bolting each end.) Then they used tar to seal it. Not pretty but it lasted decades.
Post by John Palmer on Jan 15, 2015 8:23:44 GMT -8
It's not a very clear photo, but I would doubt that it is a welded seam. I would guess it galvanized sheet metal, and it will not weld easily. Most likely it's a type of sheet metal seam called a Pittsburgh Seam. If your careful......you could bend back the "hammered over" lip on the curved section, and then use a body hammer and dolly to straighten the flat section. Look at the other fender to see how it's supposed to look.
The entire repair would take less than five minutes to put it together, after you get it all straightened. Just use a little urethane for a seam sealer when your done.
Post by mobiltec on Jan 15, 2015 20:24:59 GMT -8
By the way, that's what happens when you get a flat tire and don't notice it till the tire comes apart. John has the right fix for it. I've had to repair a few of those myself. Most people don't want to remove the cabinet that sits over it so they use good old duct tape. Keeps the spiders out.
Post by SusieQ on Jan 17, 2015 10:27:31 GMT -8
Good info here. Man314, I bet you're not the first to have this problem. Thanks for sharing.
Post by mobiltec on Jan 17, 2015 12:45:56 GMT -8
Good info here. Man314, I bet your not the first to have this problem. Thanks for sharing. I would say a good half of the trailers I have worked on have had this problem.
