Post by ladywendolyn on Nov 25, 2014 20:43:18 GMT -8
Post by vikx on Nov 25, 2014 21:20:33 GMT -8
It really is cool. With proper ventilation and a CO detector, should be fine. There really isn't much to inspect. Bench test it and see if it works.
Post by ladywendolyn on Nov 25, 2014 21:30:56 GMT -8
Thanks.. I am thinking of creating an insert space at the bottom front of the main closet.. a bit like a little hearth if done properly with a curved back.. Does bench test mean.. "plug it in to a small bottle of propane with a co2 monitor close by, and see if it works?"
Post by vikx on Nov 25, 2014 23:02:13 GMT -8
Sort of... Bench test: On a shop bench or other safe area, connect a regulated propane source (has a regulator). Leaving the heater off, sniff for propane. If no odor, you can light it. You shouldn't need a CO detector in an open area. You just want to see if it glows or burns, whatever it's supposed to do...
Post by ladywendolyn on Nov 25, 2014 23:25:54 GMT -8
O.k... I contacted a couple on Facebook who posted a photo of a ventless heater they had "restored". I would like to have an oxygen depletion sensor added if it's possible... and yes.. it's kind of funny.. no idea what it is supposed to do, but worst case scenario I'll get an old electrician guy I know to put some kind of electric heating elements in it or something... here's hoping
Post by bigbill on Nov 26, 2014 4:43:55 GMT -8
Hook it up and let it burn for a while to see how hot it gets, some of that type of heaters had be be kept a certain distance from combustible surfaces. Some as much as two feet away. while it is burning place a few pieces of plywood around the back and sides about the distance that you are thinking of placing from the mounting place in your trailer then burn it on highest setting for a couple of hours to see how hot the plywood gets. An O2 sensor system could be added but I believe it will require a pilot light and a thermocouple to make it work and most of those older heaters just had a valve you turned on and lit them with a match. I would also suggest installing a co2 alarm in the trailer as many heaters of yesteryear didn't burn clean as modern vent-less heaters and they are bad enough. you will also notice a smell as the propane burns inside a small trailer most likely. It really looks cool if it will work safely.
portajohn
Post by portajohn on Nov 26, 2014 5:48:01 GMT -8
Wow-- That is super cool! If you are looking for a cool fan, check out Vintage Vornado fans. Some of them even have a heating element to help move the heat around! Congrats on your find though.. I wish I had it!
Post by ladywendolyn on Nov 26, 2014 8:30:22 GMT -8
I will let you know what happens. I was doing some reading on "ventless heaters" last night and there are safety issues that must be carefully attended to. I will be investing the money to make this work safely. I want to find out if it would be logical to have a vent pipe that exits outside the trailer. Kind of a natural flu. I am thinking to create a steel lined place at the front bottom of my closet with some steel like the heater in the photo, then have an opening above the heater vent the flue to the outside... possibilities, possibilities..
portajohn
Post by portajohn on Nov 26, 2014 8:33:05 GMT -8
Yep.. you dont want too much CO buliding up in the camper. A CO detecter is always a good idea, especially if you have any propane appliances, lights, etc. The body doesnt like Carbom Monoxide.
Post by SusieQ on Nov 26, 2014 8:33:13 GMT -8
And check the connections with soapy water after you connect the propane but before you turn the valves on to light it. Put soapy water on it, if it bubbles, it leaks. You should do this with your fittings when you install it, too.
RJ
Post by RJ on Nov 26, 2014 8:43:02 GMT -8
Sweet little heater! As with any propane heater, proper ventilation is paramount. I about killed my younger brother and I with an old coleman lantern, burning it at night in a tent, during a winter camp trip in Montana in the late 70s. Wasn't pretty at all. Lesson learned.
