tinfishinn
1956 Century
Post by tinfishinn on Nov 23, 2014 20:22:56 GMT -8
I replaced several feet of the floor front and rear. There are several pieces of aluminum on the underside of the camper. It doesn't look like they were sealed with any type of caulk before, the pieces were overlapped and nailed. I wonder if I should remove the aluminum underneath or secure with screws and seal the seams with gutter seal or butyl tape or something? What is the best way to protect the underside of the camper?
Post by vikx on Nov 23, 2014 21:04:02 GMT -8
I don't like metal bellies. They tend to hold moisture and cause floor joist and subfloor rot. All of the metal bellied trailers I've had have had severe belly rot...
The problem comes from leaks above. As the water travels down, it settles in the belly and can't escape, resulting in a nice warm rot soup. Metal belly material also sweats, adding even more moisture.
Not sure what the remedy is. I've drilled holes in the metal to allow some breathing, but that is iffy at best. I use styrofoam insulation to keep it from absorbing any water. All trailers can get wet bellies, but when the bottom is metal, the damage is always worse.
Depending on the damage you found and repaired, it would probably be best to NOT seal the metal pieces too tightly. Hope this helps.
Post by soup on Nov 23, 2014 23:57:21 GMT -8
"As the water travels down, it settles in the belly and can't escape, resulting in a nice warm rot soup"
Uhmm....
Vikx.....
I'm not sure if I'm offended by this or not!
Still sounds icky
Post by vikx on Nov 24, 2014 0:17:28 GMT -8
Absolutely no offense to Soup!!!
Post by soup on Nov 24, 2014 0:21:02 GMT -8
Sorry...weird sense of humor. I just couldn't pass it up!
Post by bigbill on Nov 24, 2014 6:21:27 GMT -8
Post by vintagebruce on Nov 24, 2014 6:57:52 GMT -8
I think that was one of those Freudian Soups!
tinfishinn
1956 Century
Post by tinfishinn on Nov 24, 2014 17:16:33 GMT -8
When I remove the aluminum underside or at least the front and rear sections. What should I coat the underside with? I know I had water getting up underneath on a camping trip and it was still wet a week later. The camper is stored on sandy ground in northern michigan. I wondered if putting a tarp on the ground might help with some of the humidity from the ground... Or is that not a big deal
Post by vikx on Nov 24, 2014 20:32:00 GMT -8
Coating the underside: depends on what's there. Most metal bellied trailers have insulation in the floor cavity. A solid piece should be in place to protect it and hold it in place. I use a waterproofing roof coating for the underside. I found some at Home Depot that worked well: The tarp might help with critters but I doubt moisture from the ground would be a problem. As said above, most water comes from above...
tinfishinn
1956 Century
Post by tinfishinn on Nov 25, 2014 17:50:34 GMT -8
Thanks for info. Much appreciated
