jannica
Post by jannica on Sept 9, 2014 6:00:44 GMT -8
I'm sorry if I offended you but I don't want you or someone else to turn up dead or injured. I thought you said that you had low voltage across the entire trailer the other day, if so changing light fixtures won't help that because you would only be effecting the circuit the fixture is on. I DO NOT Think you are an idiot, I have been very impressed with what you have done. To prevent me from hurting your feelings in the future I will not reply to any of your post no matter what. Good luck and God bless. Just to clarify, I did have low voltage across the entire trailer the other day. And you told me after that that I should use a multi meter and disconnect each connection and test everything one at a time, starting with the power source, etc. which is what I did. I decided to put the old fixtures back in for a separate reason. I had decided prior to that that I preferred the old fixtures because they were better quality. I mentioned that I replaced them because I was just trying to list everything that I did but I think maybe it threw everyone off because it sounded like that's all I did. I think it's easy to misunderstand people sometimes online, and maybe I wasn't explaining myself very well. I hope you won't feel the need to ignore my posts from here on out because it was your advice that got me through this issue and I really appreciated your help!
