ndpap
Post by ndpap on Jul 14, 2014 15:20:46 GMT -8
Can someone recommend what I would need to run the 3 speed with reverse Fantastic fan off of 110 power? I was going to do the whole 12V with breakers and Battery for boon docking but decided for now to just get power to the fan without 12V.... THanks Nancy
Post by bigbill on Jul 14, 2014 17:27:32 GMT -8
You can install a 12 volt power supply/transformer that changes or 110 to 12 volts. run your wires for the fan down to where you would want to set your battery if you ever decide to install one and put you power supply there, put a fuse in the line where it hooks to the power supply you can purchase a 12 volt fuse holder at any auto supply. The info with your fan should give you amps required to run fan then buy a fuse just a few amps larger but not larger than the output of your power supply.
