txoil
1960 Shasta Deluxe 19
Post by txoil on Jun 14, 2014 15:04:38 GMT -8
The original shower valve in our 1960 Shasta ruptured during the very cold winter, and I have been stalling in replacing it. Now it seems I cannot locate a NOS or repro style shower valve. Anyone have a source for vintage RV/mobile home plumbing? The original, (broken) is a shower only, exposed , 3 3/8 center valve body. I cannot find a replacement part anywhere.
What I need is the valve with the handles, attached to the wall in the photo.
Post by vikx on Jun 14, 2014 22:32:01 GMT -8
I might have a more modern one out of a 68 Starflyte. Definitely not the same vintage look. Want me to search?
txoil
Post by txoil on Jun 15, 2014 9:53:37 GMT -8
Please do.. If I cannot lay hands on an original I will have to cut new holes in the shower and fit a new fixture.
Post by vikx on Jun 15, 2014 22:33:15 GMT -8
I'll check tomorrow. It seems to be in good condition, just buried in parts. LOL. "Swamper" is my storage trailer... Found this: And this:
txoil
Post by txoil on Jun 16, 2014 7:11:32 GMT -8
I really appreciate your taking time to check, but unfortunately it won't work...due to very small space behind the shower stall, it needs to be an 'exposed' type of shower valve and riser. I will have to buy a new fixture with 6" centers and install it, covering the old holes with a stainless plate. Thank you for the consideration!
Post by vikx on Jun 16, 2014 21:29:57 GMT -8
You're welcome! I pretty much knew it wouldn't work when I saw the photos...
txoil
Post by txoil on Jul 9, 2014 7:01:47 GMT -8
Whew! What a minefield! After MUCH internet searching, and finding NOTHING that is a real replacement, I had to effect a field expedient repair. The one piece brass valve body (Empire Brass Co.) had split from freezing, so I replaced the O rings in the valve stems, and filed, sanded, soldered and JB welded the split on the brass. Lots of cursing and bloody knuckles later, the valve is back in place and working, and most importantly I did NOT have to cut and butcher original sheet metal to force fit something that looks just wrong. Has anyone else had to somehow repair a broken piece that a replacement was unobtainable??
This is the valve...the part with the handles.
Post by Hamlet on Jul 9, 2014 8:29:14 GMT -8
Nice, nice, nice! I'm glad you didn't have to butcher the shower walls. Are you using the original water heater, or did you replace it?
