jlr
Post by jlr on Apr 24, 2014 16:58:08 GMT -8
Okay, so I have a question. Right now cedar 1x2 and 1x3 are about half the cost of regular wood, I thought that was kind of strange, but can we use cedar in the trailer for some replacement pieces or will this effect the aluminum like pressure treated wood would?
pirateslife
1969 Shasta Compact
Post by pirateslife on Apr 24, 2014 17:00:20 GMT -8
Are you sure that wasn't the price per foot?
jlr
Post by jlr on Apr 24, 2014 17:06:02 GMT -8
I don't think so unless Menards had their signs screwed up. The regular 1x2x10 were around $9 and 1x2x10 cedar was like $4 something.
I always thought cedar was more. Maybe they had them flipped, however the description matched up but maybe they had the prices wrong. I will be making a run there tomorrow so I will have to actually ask someone to do a price check.
If for some reason it is cheaper do you think it is safe to use?
pirateslife
1969 Shasta Compact
Post by pirateslife on Apr 24, 2014 17:30:54 GMT -8
As far as for use with cedar, the Western Red Cedar Association recommends use of 'corrosion-resistant' fasteners and materials - aluminum, stainless steel, hot-galvanized steel - with cedar, because of the corrosiveness of the wood. From a quick google search
slider
Post by slider on May 6, 2014 8:54:56 GMT -8
I'm not sure, but on the flip side cedar is supposed to be more rot resistant
Post by vikx on May 6, 2014 21:18:41 GMT -8
Cedar tends to split more easily than other woods. I haven't had the best luck with it. We tried it for the edging a while back, even kerfed it, but it cracked if put under stress.
Post by mobiltec on May 20, 2014 11:20:49 GMT -8
I don't know how the rumor that cedar resists rot got going. If that's so why did I just pull and replace 6 cedar fence posts yesterday due to the bottoms that were buried being rotted out?
