windborn
1957 Sportcraft 15
Post by windborn on May 15, 2024 10:39:19 GMT -8
Hi everyone! I was active on this board several years ago as y'all walked me through fixing up my 57 Sportcraft canned ham. After towing it around for a couple of years I ended up buying a house in Texas. I parked the camper in my yard 5 years ago and haven't moved it since! I'm thinking about getting it back on the road this summer, and thought I'd ask the experts: what are some things you would check/replace on a trailer that's been sitting in the sun and hasn't been towed in 5 years? This is what I'm thinking so far: - Fortunately I'm in the desert, and my roof repair worked well, so there isn't any water damage or mold.
- The heat of the desert, however, popped a lot of screws out of the paneling. I plan on tightening everything and replacing missing screws.
- I'll likely get new tires in case they have sun damage. I had a blowout on a trip once and don't want a repeat!
- I imagine it would be best to replace all the putty tape on the windows. Do y'all think that's worth the effort if there's no signs of water getting in?
- Check the gas line for leaks. (It just goes to a small stove.)
- Make sure the tow lights are all working.
Anything I'm overlooking?
Thanks!
Post by vikx on May 15, 2024 11:41:12 GMT -8
New trailer tires for sure. Check your tow lights and also clean them and reground the ground wire.
As far as putty goes, I would redo it all; J rail, awning rail, doors, windows and roof protrusions. It's not leaking in the desert, but you may encounter rain on the road.
Also be sure any missing/loose screws are tight in the old holes. You may have to glue wood pieces in the old holes to insure tight screws...
windborn
1957 Sportcraft 15
Post by windborn on May 16, 2024 6:09:38 GMT -8
Thanks! Regrounding the ground wire is something I wouldn't have thought of.
idaho211
Post by idaho211 on May 17, 2024 17:39:05 GMT -8
Agree with V about new tires. Good idea to clean and repack wheel bearings and inspect brakes and breakaway switch.
