idaho211
Post by idaho211 on May 13, 2024 5:56:13 GMT -8
So I have the old Sterling faucet from my 58 Shasta Deluxe I want to repair. Needs the bonnet packing, swivel spout packing, cushion disc gaskets. Problem is no parts locally to fit. Do you have a online supplier for old plumbing faucet parts?
Post by vikx on May 14, 2024 13:35:41 GMT -8
You should be able to get parts at a local mom and pop hardware not a big box. Some hardware stores have quit carrying specialty parts but our Ace usually has them. Also, bonnet packing could be replaced with string packing if done correctly.
If the faucet doesn't leak in every area, you may not need all the parts. If it ain't broke, don't fix it...
idaho211
Post by idaho211 on May 14, 2024 19:00:14 GMT -8
Yeah the faucet was under the sink when I bought so figure while it was off I would replace the stuff. The cushion discs are pretty worn and cracked.
Post by charlainec on Jul 7, 2024 11:46:12 GMT -8
Any ace should have the parts you need. the only thing you might need to do is cut a new rubber gasket if it's anything like the one I'm currently working on where it has a 2.5" rubber gasket between the body and the frame.
idaho211
Post by idaho211 on Jul 8, 2024 5:44:27 GMT -8
I found an old plumbing place that was still run by the family. Very helpful. He showed me you can add to the bonnet packing by twisting the gray plumbers tape to help fix leaks. The last mom and pop place in town.
