hotrodjim
Post by hotrodjim on May 12, 2024 4:12:07 GMT -8
Hey VTT
I just got done painting our camper with Rustoleum oil base white paint and it looks amazing.
I use a spray gun to apply the paint. My paint ratio I used was three parts oil base paint to one part acetone.
I also put one cap full of Japan drier in.
I had set my pressure at the gun at 40-35psi
sprayed a tack coat first and let it dry for 15 minutes then I applied another coat and let it sit for another 15 minutes The third coat I was looking at the panel at an angle to really see how wet the spray was laying on the panel and even.
The temperature was around 68 degrees with no wind
I have to say it looks amazing, I’ve never used oil based paint before but have sprayed automotive before and I’m very happy.
WhitneyK
'67 Shasta Compact
Post by WhitneyK on May 12, 2024 5:07:39 GMT -8
Thanks for sharing your details for success Jim. This could help others with the fear of painting.
hotrodjim
Post by hotrodjim on May 12, 2024 5:55:23 GMT -8
Forgot to mention that we stripped all the panels of the old paint and prepped the panels using self etching primer ..I believe this is a key element in the process to prevent lifting.
Post by John Palmer on May 12, 2024 8:46:42 GMT -8
I have painted bare trailer frames with Rustoleum. The trailer frame tongue's that were exposed to the sun's UV rays chalked in one year in the Southern California sun. It lays down nice, with acetone as a reducer. The last gallon of black I purchased was under $70.00, and the acetone was a little over $20/gallon.
I have had the same chalking problem with powder coated parts that have been stored exposed to the So. Cal. sun. The powder coating lasted about two years on my Spartan parts.
I painted my Marvel steel window frames, and my plastic Dometic air conditioner cover with silver "single stage" automotive quality paint, and it still looks like new after six years in the same So. Cal. sun exposure.
Painting and adhesion are all about surface preparation. How long it holds up is based on exposure, and the chemicals that make up the paint.
Post by vikx on May 14, 2024 13:31:02 GMT -8
I have used oil based Rusto for many trailers and so far none have faded or chalked. Pacific NW here.
We did have trouble using a quart of Autozone Rustoleum primer on one trailer. I used regular self etching Rusto spray cans with much better results. Not sure why the quarts didn't allow the paint to stick. Same brand, same label, etc.
newin62
1962 Shasta Airflyte
Post by newin62 on May 14, 2024 16:14:52 GMT -8
Thanks Jim for posting. Is this the paint you are talking about? It comes in a very nice white and blue that are exactly the colors I'm looking for.
This color is called Safety Blue which is what I was thinking of for below the z stripe.
hotrodjim
Post by hotrodjim on May 15, 2024 14:22:04 GMT -8
Hello Newin62
That is not the paint that I used.
The paint I used said oil based paint right on the label
newin62
Post by newin62 on May 16, 2024 2:41:59 GMT -8
Thanks Jim. I'm in Canada and it seems the regular Rustoleum oil paint isn't available here. The Rustoleum High Performance, Low VOC paint pictured above is available here through specially suppliers but is very pricey at over $200 a gallon.
At that price, the cost of epoxy primer and single stage automotive paint doesn't look quite so bad so I guess I'll be going that route.
hotrodjim
Post by hotrodjim on May 17, 2024 10:29:10 GMT -8
That is crazy at over $200 a gallon.
I only paid $50 for a gallon.
I see it listed on amazon, don’t know if that would be an option for you or not.
Thanks Jim
newin62
Post by newin62 on May 17, 2024 13:13:22 GMT -8
That is crazy at over $200 a gallon. I only paid $50 for a gallon. I see it listed on amazon, don’t know if that would be an option for you or not. Thanks Jim Unfortunately, in Canada, Amazon.ca only offers gloss black for $49 a quart. Rusto sells a product here called Tremclad but it's not very durable. I checked the Safety data sheets and the Tremclad has a completely different chemical composition compared to the Rusto oil base paint. My local body shop guy offered to supply me PPG primer and paint but the price worked out to over $800 Cdn. + 13% tax. I have been speaking with a local industrial supplier and they told me Rustoleum discontinued a few colors in the V7400 High Performance line that they are clearing out at 75% off. One color I really like is called Marlin Blue so I ordered a gallon of it for $51. I'm going to experiment with it on my old siding panels and if it sprays well I'll use it for below the Z stripe and splurge on a gallon of white for the rest.
hotrodjim
Post by hotrodjim on May 19, 2024 16:20:18 GMT -8
I don’t know the regulations in Canada on paint, But Canada is a beautiful country.
newin62
Post by newin62 on May 20, 2024 2:00:34 GMT -8
I don’t know the regulations in Canada on paint, But Canada is a beautiful country. Our landscape is cut from the same rock as the US and can be very easy on the eyes if you know where to look. We really do live on the ideal continent to explore with a trailer.
