williesrv
1969 Boles Aero
Post by williesrv on Jan 24, 2024 10:05:48 GMT -8
I am working on a 69 Boles Aero which has an A&E awning on it. The front latch release button is broken off. I have searched online and do not see anything available. It looks like A&E has been bought out by Dometic. Any leads are appreciated.
This is what it is supposed to look like:
Post by Teachndad on Jan 24, 2024 10:13:18 GMT -8
Hi Willie,
I can't help you with this one. This is a very oddball accessory for the trailers we usually see around here. Just me, but I think this would be more something you might see on a vintage Airstream. All I can suggest is to ask on some Airstream forums. I think you would have more luck there for this particular question.
But, hey, maybe someone here can help.
Cheers,
williesrv
1969 Boles Aero
Post by williesrv on Jan 24, 2024 11:31:34 GMT -8
Hi Willie, I can't help you with this one. This is a very oddball accessory for the trailers we usually see around here. Just me, but I think this would be more something you might see on a vintage Airstream. All I can suggest is to ask on some Airstream forums. I think you would have more luck there for this particular question. But, hey, maybe someone here can help. Cheers, Rod Hi Rod,
Thank you very much for the suggestion.
ruderunner
Post by ruderunner on Feb 10, 2024 7:44:01 GMT -8
Is the little rod threaded?
A small pushbutton like that ought to be easy to make, attachment might be the tricky part.
