Post by Teachndad on Jan 12, 2024 23:28:42 GMT -8
Hi Friends, I need to finish up the rear wing on the streetside wall of my 57 Westerner. The image below shows the missing boards of the radius. As originally manufactured, the ends of the horizontal bracing in the wall were not butted up against the radius boards - no staples in any ends of the horizontal bracing. Below is a picture of a clamped on sample of a new rough cut radius. The clamped board is a tad wider than what was there originally. Should I make sure during the installation of the new wing boards that they are connected with pocket holes or leave them unfastened as originally built? Obviously not fastening them together to create a butt joint is less work. To fasten them will take some engineering. I hope that makes sense. Thanks, Rod
newin62
1962 Shasta Airflyte
Post by newin62 on Jan 13, 2024 9:12:35 GMT -8
Hi Rod. About 25% of the joints on my trailer had no connectors and the perimeter framework was only held together with twisty nails through the birch ply. It held up well for 60 years so I assume that missing a few joints won't matter too much, especially if you are gluing the ply to the frame. That being said, I remember you mentioned in your restoration thread that you were thinking of changing some of the ash paneling. If you still want to have that option before you erect the walls I think you should definitely throw in a few connectors and pass on the glue.
Post by vikx on Jan 13, 2024 14:03:30 GMT -8
I say make it as strong as possible. Connect as you can without compromising the boards. Many of my canned ham windows were "loose" and attached with aluminum straps but I also beefed them up, curving the boards rather than use the aluminum hinges...
Post by Teachndad on Jan 14, 2024 21:14:14 GMT -8
Thanks Vix and Peter. I was initially thinking the same as Peter – if it lasted this long, then why not leave it the same way, but once I got the wing boards in place, it became apparent that it will be necessary to reinforce the ends of the horizontal braces. The mounts for the hanging bunk are in this area as well as the side of the bed frame. Today after yet more missteps, a common occurrence for me ![???](//storage.proboards.com/3684717/images/F8wleeitGL3uPbf8waGT.png) , I was able to tie in all the boards in the wing. Note: All wing boards are oversized and have yet to be trimmed. Below is the current representative for the progress I made today. I have some more questions below for anyone to answer. Color legend:Short Purple lines are pocket holes. i.e. three lines is three pocket holes Dark red zig zag lines show where there is actually no stud. Red open rectangles are where backer boards need to be placed to support the sides of the bed frame. When the image is magnified, you can see several small arrows written on the paneling that indicate holes in the paneling. I marked these years ago when as a reminder when I would get to this point. These were from the screws of the bed frame – missed their mark! The bed needs more support. Blue open vertical rectangle marks the possible location of an additional short stud. Is this redundant once the backer board(s) are added for the bed frame or an added necessity? Green and orange circles represent gaps. The green gap is a little less than 1/8”, the orange gap, is wider at the top and narrower at the bottom. Should I glue in a wedge in both gaps and then pocket hole to the wing board through the wedges Or sister a piece of lumber underneath each horizontal brace so that it can have a tight butt joint at the wing board? I hope those are clear enough. Thanks, Rod
Post by vikx on Jan 15, 2024 13:11:06 GMT -8
Again, I say make it strong. The bed support boards are important and also back to back boards at the very rear of the trailer. In other words, Get the bed supports in place, then measure how high on the back panel the support needs to be.
Drill a small hole in the panel so you know where to place the outside board. I glue and screw both boards and they are connected to the walls as well. This makes for a very strong bed support at the back.
Administrator ![*](//storage.proboards.com/forum/images/stars/star_red.png) ![*](//storage.proboards.com/forum/images/stars/star_red.png) ![*](//storage.proboards.com/forum/images/stars/star_red.png) ![*](//storage.proboards.com/forum/images/stars/star_red.png)
Post by nccamper on Jan 17, 2024 17:16:51 GMT -8
I agree with te post above….fastners Over glue. Glue was never used at the factory so I’d keep it to a minimum.
![*](//storage.proboards.com/forum/images/stars/star_lavender.png) ![*](//storage.proboards.com/forum/images/stars/star_lavender.png) ![*](//storage.proboards.com/forum/images/stars/star_lavender.png) ![*](//storage.proboards.com/forum/images/stars/star_lavender.png)
Post by mobiltec on Jan 19, 2024 11:19:36 GMT -8
Pocket hole and glue.
Post by Teachndad on Jan 22, 2024 22:45:13 GMT -8
Hi Friends, I added glue and screws to the joints and added two pieces of lumber for additional support. ![](https://live.staticflickr.com/65535/53481876538_28c96dfc49_z.jpg) I have 1 of 2 backer boards with pocket holes drilled, cut and ready to support the bed frame, but decided not to add it at this time. I am going to wait until the walls are up and I add the bedframe to the interior. Then I will add the backer boards. The clamped areas on the wall are where I added a white narrow strip of 3/8” thick poplar. These were left over cuts from the skirtboards. In the clamped areas, original screws or staples for the skin for anchoring the window frames barely seated and sometimes missed the lumber because the framing was too narrow. So, I glued the 3/8” strips in place to widen the framing boards. This seemed to me to be a good compromise for strength and not disturbing the original still good lumber. The curved edge of the lower radius board will be cut/shaved to meet the end of the original but deteriorated skirt board that I laid in front of the new skirt board. ![](https://live.staticflickr.com/65535/53480831647_39780cf5dd_z.jpg) Cheers, Rod
Post by mobiltec on Jan 23, 2024 22:36:41 GMT -8
Remember that notched part which allows for the Curbing to end.
Post by Teachndad on Jan 24, 2024 5:31:39 GMT -8
Hi Larry,
Gotcha. As stated earlier in the thread. The streetside skirtboard was heavily desintigrated so I didn't have a decent template for cutting a new one. The original taped together skirtboard that's lying in front of the new skirt board is actually the skirt board from the other side (curbside). Incidentily, that had a huge knot in it which came apart. Hence the masking tape to hold it together. I had to make a decision whether to precut the streetside skirtboard based on the curbside skirtboard or wait until the entire curbside wall was completed and then match to that one. I chose the latter for better or for worse.
This is my first restoration and it's been like trying to get to the center of a maze. We all know what that's like.
Cheers
Post by mobiltec on Jan 25, 2024 17:31:45 GMT -8
Well if you are reusing all your old skin then these profiles are very important. You need to keep them the same when making new. But if you are putting new skin on them, just make sure they are both the same.
