Prowler@Nola
1976 Fleetwood Prowler
Post by Prowler@Nola on Oct 5, 2023 11:38:29 GMT -8
Hi there, I just started working on my '76 Prowler, and I'm investigating and doing demo work on the roof. I'm looking for advnice on how to proceed with roof repairs.... At the back of the roof, there is a weirdly folded and screwed seam between two sheets of aluminum that seems to be the source of water damage. The top sheet folds up and back over itself for about an inch, the bottom just extends under the top, and they were screwed together, no washers, with butyl in between and a lot of silver putty covering the whole shebang. The top sheet fold scoops "up river" if you will, so that dirt and water get caught in this pocket. The screws were definitely not waterproofed other than being covered by putty. I have removed as much of the putty and all the screws, to have the two sheets un-coupled. I'm wondering if I should replace a whole section of the aluminum, and maybe move the seam a few inches down, so that it's right above the tail lights, rather than on the horizontal part of the roof. There's also a section above the kitchen that has slumped, and has been coated with a black tar kind of material, then over coated with roof rubber. Is there a way to fix this without replacing that sheet, or the whole dang roof? Thanks! Photos and videos of what I'm talking about below... The seam before I took the screws off Prowler roof explorations by Kate Clarke, on Flickr Here's a video of the un-screwed and loose overlap IMG_5551 by Kate Clarke, on Flickr exposed seam and tank vent IMG_5531 by Kate Clarke, on Flickr Detail of the seam at the edge of the roof Prowler roof explorations by Kate Clarke, on Flickr tarred and slumped area of the roof, over the kitchen area. Prowler roof explorations by Kate Clarke, on Flickr
Post by vikx on Oct 5, 2023 11:51:54 GMT -8
There isn't much help for this roof other than replacing it. The amount of goop alone looks like days of work. Start by removing ALL the screws and roof protrusions, then the roof metal. This may entail loosening or removing the front and back skins/windows as well.
Most likely to have severe framing damage to the rafters and edge wood, that will need to be repaired before worrying about the roof. The roof needs new metal but the trailer must be sound before proceeding.
There is no "quick fix" for trailers like this. They must be repaired properly before the leaks can be stopped.
Start by searching for a covered area to work. Remove the skins to begin repairs. Budget for expensive lumber costs as well as supplies (putty, screws, nails, etc) If there is an A/C on the roof, it probably caused quite a bit of the sagging, as they weigh 100 pounds+.
