trooper
Post by trooper on Sept 23, 2023 11:23:31 GMT -8
Good day I have a 1955 1500 that the roof vent is missing. Can someone tell me what was used. Maybe a picture. Thanks for the help
Ken
Post by vikx on Sept 23, 2023 12:55:16 GMT -8
Welcome Ken. The vent opening should be a standard 14" x 14". They are available at most RV shops or online. Check to be sure the vent has good sound wood before installing the new one, otherwise replace. It's always best to shim the vent framing higher than the roof if that wasn't already done. Vent Shim 1 by VK Lee, on Flickr Use putty on the flange and the screws will ooze it as you tighten them. Fantastic Fans are a good vent replacement; they fit the old hole perfectly. Dicor on a roof vent by VK Lee, on Flickr
trooper
Post by trooper on Sept 23, 2023 14:49:45 GMT -8
Hi Sorry I wasn't clear. I'm referring to the heater chimney and the cap that goes on top of it.
KEN
Post by vikx on Sept 24, 2023 12:50:36 GMT -8
You might find a heater cap at a used RV parts lot. Trailertrasher1@gmail.com sometimes has them. It takes a while for a response. They are fairly common. Another source may be a modern heater supplier.
You can also have a sheet metal fabricator make you one.
