Boondocking 12 VDC electrical with 110 VAC dependent stuff
Jul 27, 2023 15:16:18 GMT -8
WhitneyK likes this
Post by davesshasta16sc on Jul 27, 2023 15:16:18 GMT -8
VTT Peeps and Professionals,
I have been working hard on researching the best plans for my electrical system in my 1972 Shasta 16-SC. It seems the trailer was re-wired for 110 VAC only from shore power. So, I am going to be re-wiring a 12 VDC system except for the appliances. When on Shore Power I will be pushing 110 VAC to my converter and 110 VAC dependent appliances, directly. I am going to use a dorm fridge, a counter top Breville toaster oven and a media center PC with monitor. All will run on 110 VAC only and therefore, can run on shore power when available and the inverter will need to be off. When boondocking, those same 110 VAC dependent appliances must pull power from an inverter and so the converter needs to be off.
There was a similar thread posted regarding this back and forth here:
vintagetrailertalk.freeforums.net/thread/12684/ac-dc-back-again
Now there are some pretty fancy and expensive Transfer switches for this situation but I kept coming back to the same question:
When on shore power, the 110 VAC will go to the converter, then the fuse box. Then it will go to the inverter, which will try to send 110 VAC to the 110 VAC dependent outlets. But those outlets will already be getting current from the shore power. Converse is true when boondocking. The Inverter will pull 12 VDC from LiP04 battery and send it to the 110 VAC only plugs. The converter will receive 110 VAC from one of those plugs, so it needs to be off when the inverter is on so it does not take the 110 VAC from the inverter and try to send it back into the 12 VDC system.
Q: Instead of a Transfer switch, can I put in two simple on-off switches for the converter and inverter? Turn off the converter and the inverter on when boondocking and turn on the converter and the inverter off when on shore power. Then the 110 VAC dependent outlets will only receive one current source, and the converter will not try and take the 110 VAC coming off the inverter and feed it back into the system as 12 VDC.
I think that actually does make sense.
Here is my diagram, I included Vikx Frame Junction Box, which I will install and my plans for Solar re-charging of my battery as well as the two switches:
The White Whale_Electrical Diagram_Planned by David Porzio, on Flickr
I believe all the components are there.
I do have one other question in regards to the hot charge wire going from the Frame J-box to the Hot side of the battery. I presume that is to charge the battery while towing the trailer? If so, does there need to be some sort of charge regulator or controller between the Hot Charge line from the Tow harness and the trailer battery to manage charging a LiP04 battery? I believe VIKX diagram (see below) was done under the presumption the battery is Lead Acid.
![](https://live.staticflickr.com/65535/53076307970_8db7703818_z.jpg)
VK Lee Frame J Box Wiring by David Porzio, on Flickr
I hope what I am asking makes sense:
1. Does this wiring diagram look correct?
2. Can I install simple on-off switches instead of a transfer switch to control converter and inverter when drawing shore power vs Boondocking/Battery Power
3. Do I need a charge controller between Hot charge wire from tow vehicle and the Trailer LiP04 battery?
Thanks in advance
Framing about done almost ready to put on skin and roof.
Dave's Shasta 16-SC
Shore Power | Boondocking | |
Electrical Input | 110 VAC | 12 VDC |
Inverter Status | Off | On |
Converter Status | On | Off |
![](https://live.staticflickr.com/65535/53076352218_bf7bec9036_z.jpg)
Thanks in advance
Dave's Shasta 16-SC
