hotrodjim
Post by hotrodjim on Aug 30, 2022 14:36:23 GMT -8
What would be the correct inch of WC” for my Holiday range/stove.
We do not have any other appliance that we will be using.
The original gas regulator is old and has no markings listing gas pressure..
I’m assuming appliance running on propane is 7” WC for propane. This regulator is the only one that is outside by the tank.. I’m planning on just using a small single tank..
Post by vikx on Aug 31, 2022 10:43:14 GMT -8
11" water column.
hotrodjim
Post by hotrodjim on Sept 1, 2022 3:24:20 GMT -8
Thanks vikx I wanted to ask before assuming.
Post by vikx on Sept 1, 2022 10:07:38 GMT -8
As far as I remember, all RV appliances are at 11" WC. That's what we used to test for anyway.
Side Note: Newer RVs sometimes came with a BBQ hookup. That was the same pressure as inside the RV, so needed a special custom BBQ to work with the lower pressure. A real surprise to new owners...
