gerryd
Post by gerryd on Mar 20, 2022 15:38:40 GMT -8
Are there any recommendations regarding charging an auxiliary deep cycle battery through the 7 pin vehicle harness? I don't want to over charge it when hooked up to the vehicle alternator. I see in other posts that there should be a circuit breaker between the battery and the appliance/lights in the camper. Is that enough resistance to not overcharge? Also any brand or manufacturer of deep cycle battery that works best?
oldman
Post by oldman on Mar 20, 2022 17:10:01 GMT -8
There are a lot of variables to correctly answer your questions. But depending on your type of vehicle, battery, how long you are driving, etc. it will probably never be fully charged. So I wouldn't worry about overcharging the battery. And the circuits between your battery and camper lights/appliances are completely separate from the charging circuit. If you want a good deep cycle battery look for brands like Crown, Trojan or Rolls. Those that are true deep cycle that have a amp hour(AH) rating, not a marine type battery.
Post by vikx on Mar 22, 2022 12:27:44 GMT -8
I agree. The vehicle will not overcharge your battery. On my smaller hams, I use a battery "maintainer" when on shore power. It's automatic and also won't overcharge. For larger trailers and systems, a Progressive Dynamics converter will work well and provide clean and constant 12 volts.
Post by wisconsinjoe on Mar 25, 2022 20:01:05 GMT -8
Look for a 200 Amp hour deep cycle battery. Note that you can count on only 100 Amp hours of use without charging (like off grid boondocking). I use a good charger/converter with "smart charging" that trickles as it nears topping pount.
