keiths
1962 Rancho El Rae
Post by keiths on Jan 15, 2022 20:48:52 GMT -8
I need to raise my 1962 Rancho El Rae. I was going to use a longer shackle but then found I also have a broken leaf spring. Now that I have to take it ALL off I may as well just put the springs on top of the axle. But do I need anything else or can I just set it on top?! Of course I would use new square bolts and all, but what else do I do? I does not seem like there is any type of riser since the axel itself is square! photos.google.com/u/1/photo/AF1QipNDP3OBERuoxFc1jZYKXbatCXGbds9r7uUk5exP
Post by vikx on Jan 15, 2022 23:17:36 GMT -8
One way to raise the trailer is to put the axle underneath the springs. It gave me 3.5- 4 inches on my Shasta. Don't "flip" the axle as it will cause tires to wear funny.
WhitneyK
'67 Shasta Compact
Post by WhitneyK on Jan 16, 2022 15:26:14 GMT -8
I can't see your photo in google docs, but here's a link to a recent thread where I referenced / showed pics of moving the axle to under the springs... Axle
Hope that went as I planned... Whitney
pthib
1966 Buco
Post by pthib on Jan 18, 2022 14:48:54 GMT -8
Depending how much lift you want an axle and spring shop could supply you with lift blocks to install between the axle and springs. 4X4 truck guys do this all the time to lift their vehicles. Always a good idea to replace the axle u bolts and nuts when replacing an axle or springs.
Teachndad
Post by Teachndad on Jan 19, 2022 23:21:12 GMT -8
Hi Friends,
There is also a bonus added in with new springs. The original springs will most likely be sagging a little. If you add a new axle with new springs, the new springs buy you a few more inches in height over the original sagging springs.
Cheers,
