chicajax
1963 15' Oasis
Post by chicajax on Jun 30, 2021 9:42:26 GMT -8
I've recently become the proud owner of a 1963 15' Oasis. After spending a considerable amount of hours online, I haven't found any other that has a similar layout: twin seat dinette at the front, kitchen with 4 burner Princess stove/oven and double sink facing the Dometic fridge in the middle and small bunk over gaucho bed facing the bathroom (toilet is missing, but has stainless steel shower and I found a sink that hangs on the wall of the shower). From the floorplans that I've seen, it's not common to have a shower in the Oasis 15'? I've read through all the posts here that contain Oasis and it seems that people really like them and I can see why. I've spent the better part of the last week cleaning her and exploring her very clever design. She's definitely going to need work, which I am not afraid of doing and I do plan on skinning her to examine the extent of rot, but wanted to get to know her a bit before diving into some of the more major things. A few things I'd appreciate advice on: - Checking her systems: propane, electrical, water... I don't want to start a fire or cause an explosion while checking out her current state. What do you recommend I do?
- Checking out her appliances: is it recommended that I test each appliance one by one on the system? Or is there a way to hook them up directly to a propane source to test? It's a Glen Aire heater, a Dometic fridge (teal!) and a Princess stove/oven (also teal!). This is my first exploration into the world of propane fridges (the physics is fascinating) and would ideally love to keep all the original appliances if possible.
- Water heater: the chap we purchased her from mentioned that he likes to install inline water heaters. What are the thoughts on this?
- Is there anything else I should be aware of with Oasis trailers? I saw the posts talking about the damage on the front due to a butted joint instead of an overlapped one as well as the walls being built on the floor which isn't all that common. Any major concerns?
- The wire to attach to the car to operate brake lights/turn signals, etc has been cut; is there any specific reason that this would be the case?
Thank you in advance! I'll attach photos because I know how much I enjoy looking at other's trailers. Jackie
Post by nccamper on Jun 30, 2021 10:48:14 GMT -8
Welcome!
Oasis made a sturdy camper. Your layout is unique. The bathroom alone is unusual for a small camper. Shasta made a similar model but didn’t sell many.
1. I would suggest the book written by a member (vikx) on appliances and the second book on general camper repairs. I would also check videos done by a member at cannedhamtrailers.com. vikx will probably see this thread and comment shortly. 2. Water heater: with a shower I would definitely consider one. an electric version will require you to have a generator or be on the grid to work. 3. I believe your oasis was one of the few campers with thicker walls. Heavier but very sturdy and easier to run systems in the walls. 4. I would run a new tow wiring harness during your restoration.
It appears your interior panels are ash with a lighter than usual tint finish. Very nice but very hard to match.
keep us poster on your restoration.
(excuse any typos. I’m overseas using Siri on a tiny screen)
Post by vikx on Jun 30, 2021 12:51:10 GMT -8
Welcome Jackie. I have done two Oasii, a 64 and a 65. That interior color wash is particularly hard to duplicate. I used a tan matching paint and then wiped before dry. It depends on how bad the rot is whether you can save panels or not. One of mine was pretty bad and a previous owner had painted it white. ugh. Skip the sink in the bathroom and be VERY CAREFUL buying fixtures until you figure out if your waste tanks are any good. Some trailers didn't have tanks at all; they were built into a Monomatic toilet. (there's a reason we call these fecal fountains) Plumbing fixtures are one of the LAST things you need to worry about. Many people cut the brake wires because they want a 4 way plug to operate the tow lights. I also recommend a new tow wiring harness to a J box, then connect a 7 way cord from there to plug into the vehicle. Your GROUNDS are most important, so be sure you install a new ground bolt and wires. To test the gas system: 1. Turn off all appliances, don't forget the gas light! Eyeball the gas lines from the front of the trailer as it radiates out to each appliance. Get under the trailer to do this. The tank should be connected to the gas system with a regulator and hose. 2. Assuming you have gas, slowly open the gas tank valve. Listen. If you hear a Hsssss, turn the tank back off. Repairs are needed. If no Hssssss, open the tank valve fully. Listen, under the trailer and inside. If no Hssss or GAS SMELL, close the trailer for an hour. If no smell, your gas system is probably intact. Note: open propane lines are loved by spiders, so if the lines were cut or open, your system needs to be air blown. If repairs are needed, you should take your trailer to a certified RV shop for repairs. Gas is safe if you maintain the system. Oasii are known for having metal bellies which causes severe belly rot. You may have to do more repairs than anticipated depending on what you find. Take your time. We are here to help. I say don't rush, follow the order of build and hang in there. We all get to spinning our wheels. Here is my 64 Oasis: 1964oasis.shutterfly.com/ Click on Pictures and Videos to view the albums.
chicajax
1963 15' Oasis
Post by chicajax on Jun 30, 2021 14:37:41 GMT -8
Thank you both for the quick and thorough responses. I do plan to take my time and I know, as with most projects, that this is a ball of yarn to unwind... who knows what's trapped inside. I can guarantee rot... I'm excited to get vikx book and will buy it today. There is a water heater on it currently. It looks like it's on the outside of the trailer and the holding tank is in the bottom of one of the kitchen cabinets. It'll be another thing to test. Would an inline be able to work off of solar? It's something we're considering. There's a fine line between preserving and modernization, so not even sure what the group thinks of solar... The ash interior is something that I do want to preserve instead of painting it. It seems like the trailer sat for a long time under some heat as the varnish and finish are both very peeling and fragile. That's fine as I was planning to take my time sanding and refinish all of the interior. For the damaged panels, I'll try to replace with ash veneer to keep it all consistent. We will see... Understood re: buying things until testing the systems. The sink is actual part of the OEM build. I found it hanging out under the main bed and originally thought it was meant for the outside until I saw the bar in the shower that it fits perfectly on. Quite clever, actually: I'll do a more thorough investigation under her. Really appreciate the advice (and the photos, vikx! Lovely job on the '64.) So glad that y'all have created this invaluable resource.
Post by danrhodes on Jun 30, 2021 15:48:00 GMT -8
I had an ash camper and ended up just replacing the rotten panels with birch and using what was good to fix the cabinets, but my camper was a disaster. My camper finish was also very brittle, perhaps something about ash and shellac? I used a cabinet scraper to flatten and remove the loose material then resealed with shellac and it's holding up well. Mobiltec has had good luck matching birch with white oak paneling.
idaho211
Post by idaho211 on Jul 4, 2021 16:55:45 GMT -8
Welcome. Looking forward to your pics. There is good advice on this site. Have fun with your trailer. Any local trailer clubs in your area? It is nice to have some local support. The paneling is the same color as my Kenskill’s but has the white paneling lines. Good luck.
chicajax
1963 15' Oasis
Post by chicajax on Jul 12, 2021 9:07:44 GMT -8
I'll have to see about local trailer clubs; it's Bend, OR, so I'm sure that there are some being the home of Flyte Camp and so many trailers.
Just got back from vacation and looking forward to planning out pulling up the skins to see what's going on underneath.
Looking through a lot of the posts it seems people who start working on trailers the first time get over excited about proceeding like a house remodel: gut and then fix... or post about how they are planning to gut, then get responses saying "Don't do it! It's the structure!" and never sign in again.
I am new to this and have a background renovating homes and am SO GLAD I found this forum.
Post by Teachndad on Jul 18, 2021 7:01:28 GMT -8
I'll have to see about local trailer clubs; it's Bend, OR, so I'm sure that there are some being the home of Flyte Camp and so many trailers. Just got back from vacation and looking forward to planning out pulling up the skins to see what's going on underneath. Looking through a lot of the posts it seems people who start working on trailers the first time get over excited about proceeding like a house remodel: gut and then fix... or post about how they are planning to gut, then get responses saying "Don't do it! It's the structure!" and never sign in again. I am new to this and have a background renovating homes and am SO GLAD I found this forum. Nice Job! and Thanks for researching first and then starting so you don't make the gut it first mistake. Yes, unlike a house, stick and tin trailers are repaired from the outside in and not like a house from the inside out. Cheers, Rod
chicajax
1963 15' Oasis
Post by chicajax on Jul 25, 2021 8:49:10 GMT -8
Finally got Flickr set up and here's a link to the album:
<a data-flickr-embed="true" href="https://www.flickr.com/photos/55487823@N08/albums/72157719599646552" title="1963 15' Oasis Trailer"><img src="https://live.staticflickr.com/31337/51335342705_b8bfce6afe_z.jpg" width="640" height="480" alt="1963 15' Oasis Trailer"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Post by vikx on Jul 25, 2021 10:02:48 GMT -8
Really nice! I think you can save most of the paneling... the discolored areas by the windows should be easy to camoflague with a matching tone paint. Thin it down and wipe wipe wipe.
chicajax
1963 15' Oasis
Post by chicajax on Jul 30, 2021 12:22:23 GMT -8
I finally got VK's book and it's wonderful. I've read it twice and finally got up the courage to attempt removing the skins. I've gone slowly, labeled everything and have a couple questions: The cover for the water heater came off fairly easily and I am left with this:
It seems stuck now and it's overlapping the skin. Any suggestions on how to get this out? Also, more out of curiosity than anything else, the running lights when removed seemed to have decayed cork between them and the skin. Is this normal? So far the windows and other items have come off smoothly. Working my way around and hope it continues!
Post by vikx on Jul 30, 2021 14:34:39 GMT -8
Are the water lines disconnected from the water heater? Also, the top piece may have rusted to the inside but it should come out with the heater. Make sure the flange is loose all the way around. It looks like it should just slip out...Grab a holt and YANK.
Post by Teachndad on Aug 2, 2021 11:49:49 GMT -8
Hi Friends,
The marker/running lights used to have cork as a gasket. The cork is always dried out or decaying or just long gone. Remove the remnants of the cork and then you can replace with gray putty tape instead and it works quite well. On a warm day, it will seal as you tighten the mounting screws slowly as the gray putty tape starts to ooze. Don't over tighten. Scrape off excess with a plastic putty knife.
Cheers,
Post by vikx on Aug 2, 2021 11:55:42 GMT -8
Thanks Rod. It also helps to "frame" around each light while you're doing repairs. That way, the light screws have something to grab into.
Post by hlschledge on Nov 26, 2021 21:43:16 GMT -8
I have a '65 Oasis with a similar layout as yours. We've removed enough of the skin to do the frame work we needed to and are in the process of insulating and reinstalling everything. As previously stated, the hardest part is going to be matching the interior paint/stain color! 20211119_160600 by HL Schledge, on Flickr 20211126_163800 by HL Schledge, on Flickr
