pirateslife
1969 Shasta Compact
Post by pirateslife on Jan 12, 2014 19:34:37 GMT -8
hey guys, i finally got to start going back together with the shasta. i was wandering if someone could give me the height of the rear table mount bracket to the top. also, the height of the inner frame work for the bed. from what i can tell the bed frame comes to the top of the wheel well? thanks guys
Post by soup on Jan 13, 2014 5:25:05 GMT -8
I wish I had one parked here right now and I'd go get some measurements for you. I'm sure someone will chime in here soon. Good Luck, at least this bumped you back up to the top of the recent list! soup
Post by bigbill on Jan 13, 2014 6:37:36 GMT -8
I would block the table up with the folding leg on the floor till it was level then measure from the table bracket to the floor to make sure that you had the right height.
pirateslife
1969 Shasta Compact
Post by pirateslife on Jan 13, 2014 13:57:20 GMT -8
Thanks guys. Hopefully I can use the reclaimed table from a pop up. This would be so much easier if someone hadn't thought it was a good idea to just gut it for more room. Sad part is they pulled it down the interstate like that......rot and all
Post by SusieQ on Jan 13, 2014 14:19:35 GMT -8
See if this helps you with the table. Can't help with the beds  Unless you want measurements from my 62 compact. I didn't post the table info earlier because I think the table legs were different in the early models but the height of the table leg and thickness of the table is listed which might still help you. Good Luck!
