glp23
Post by glp23 on Apr 8, 2021 20:43:10 GMT -8
20210408_170706 by Greg LaPrad, on Flickr Hello I recently purchased a 1964 Santa Fe Cub. Any suggestions on how to easily remove these screens? Does the window frame need to be dismantled? Thanks in advance!
PT
Post by PT on Apr 8, 2021 22:11:31 GMT -8
The screens are usually held in the lower channel by gravity alone. Gently slide the screen straight up and the bottom of the lower screen frame should clear the channel edge. Get a knife or similar under the frame and shimmy it out of the channel. Might take some wiggling but it should work... Nothing needs to be dismantled.
