Post by vikx on Oct 21, 2020 21:33:08 GMT -8
I will be moving this thread to tow wiring. All the wires are 12 volt and look like tow wiring. Something is not right with your wiring. It looks like the red wire is jammed into the 7 way plug? They may have tried to run the inside lights with this odd connection??
Small batteries such as this are normally used as a back up brake power to the break away switch. If the trailer disconnects and pulls the break away pin, the brakes will stop the trailer.
I think we need more pictures. Where does the red wire lead? The pink wire? Maybe a picture further away?
