kanolan
Post by kanolan on Sept 27, 2020 4:05:50 GMT -8
We have a 1969 Shasta with the side skins off.
It did not have a vapor barrier when we opened it up. All of the rotted wood was from areas that leaked - around the windows, behind the lights, access doors, J rail, and it looks like washed dishes where water went behind the cabinets.
We are not planning on pulling the roof off. All of the wood at the top 1.5 feet seems good. We don’t see any interior damage on the ceiling, and the top awning, J rail, and corners are nice from the outside.
Should we add a vapor barrier, even if it is just for the sides? It’s survived 50+ years without one. Can adding a vapor barrier cause problems with the skins fitting back on? I’m not sure how it would help with future leaks and outside water because a vapor barrier is tacked in and cut at the windows and lights.
Also, for water sealing, should we putt putty tape behind the lights where they attach? It appears they were originally screwed into the metal with either nothing behind them or that foam adhesive tape. Needless to say they leak. What have others done?
Thanks!!!
Post by John Palmer on Sept 27, 2020 18:21:30 GMT -8
I'm kinda new to working on Shasta's.
I'm curious, how do you remove the sidewall skins, without removing the roof skin? Does the roof skin not bend over the wall skins?
The purpose of installing a vapor barrier is to prevent the warm moist air inside a trailer from being able to directly contact (and condense) on the inside of the cold outer aluminum skin. If you omit the usual fiberglass insulation, and instead use a ridged styrofoam sheet insulation with taped edges works the same as a vapor barrier. You want to do everything possible to eliminate any possible contact of the interior warm air with the cold skins. In my opinion, most wood dry rot comes from this constant condensation running down the wall framing, NOT exterior leaks. Just my observation over the past ten years of rebuilding vintage trailers.
John
Post by vikx on Sept 27, 2020 21:35:15 GMT -8
I use putty behind the lights and any other protrusions. I also use an extra ground wire for each light.
Post by nccamper on Sept 28, 2020 10:55:53 GMT -8
“Should we add a vapor barrier, even if it is just for the sides? It’s survived 50+ years without one.”
Under cover any camper will survive. In the desert most campers will survive. On the east coast where it rained 5” last week nothing will survive 50 years outside but a vapor barrier will help.
I second john’s question, how did you get the sides off with the roof on?
Post by Hamlet on Sept 28, 2020 11:43:24 GMT -8
Hmm, hadn't thought too much about this. We have the foam insulation and have never had a problem with condensation... except for the rear window. It's already damp enough where we live, but at night, that window just makes moisture like crazy. we have been really careful to get it wiped up and keep it dry, so we haven't had any water damage, but is there anything that will keep the window from sweating?
Post by John Palmer on Sept 28, 2020 14:30:46 GMT -8
Hmm, hadn't thought too much about this. We have the foam insulation and have never had a problem with condensation... except for the rear window. It's already damp enough where we live, but at night, that window just makes moisture like crazy. we have been really careful to get it wiped up and keep it dry, so we haven't had any water damage, but is there anything that will keep the window from sweating? Let's explore..........at night that window makes moisture like crazy. Yup! it sure does. It's a difference in surface temperature. The outside surface is cold, or at least cooler than the inside temperature. The inside surface is warmer, and has moisture from people breathing, a pot of boiling water for the spaghetti, and maybe a coffee pot brewing. It's exactly the same thing that happens when you take a hot shower and step out to find the bathroom mirror all steamed up. I'd bet that the window collects water "only when camping" with people and food preparation, not when the trailer is stored at home. Well guess what........the very same thing happens to the entire inside of the aluminum skin on your trailer. You might be able to wipe up the water on the window, but you cannot get to the water that condensed on the inside of the skins, which is going to rot your newly repaired wall framing. I think anything you can do to seal, or at least slow down the travel of the warm moist interior air from contacting the cold skins will improve the cycle of wood framing rot. Solid Styrofoam, cut to tightly fit into the wall/ceiling studs pockets, then sealed with aluminumized duct tape becomes effectively a vapor barrier. On a stick and tin style construction, using a house wrap over the entire wall and roof area is a easy choice, but for the riveted skin style trailers it does not work. On the riveted skin trailers it's easier to just install the foam sheets from the inside, then tape them to get the air seal. I used 27 full 4' by 8' sheets of Styrofoam on my Spartan for insulation. I always have my vents cracked open about an inch even during a rain storm (no they do not leak during a rain). When installing Styrofoam on the ceiling of a canned ham, you can take a straight edge, and a single sided razor blade and cut one inch wide kerfs into one side. The cuts only need to cut the plastic sheet. With one side cut, the sheets will easily bend into the curve to match your roof curve. It's easy to do, and not messy if done with a razor blade. John
Post by Hamlet on Sept 28, 2020 14:42:03 GMT -8
Thanks for the reply, John. We did the tightly fit foam insulation that has a vapor barrier on one side. That was ten years ago, and as we have peeked and poked this last few weeks, everything looks good. We lifted skins and the framing is still solid, even below the roof rear window Is still solid. So we have been lucky. I suspect that any time there’s a single pane window this will happen. We will just have to keep an eye on it.
kanolan
Post by kanolan on Sept 28, 2020 17:12:59 GMT -8
I'm curious, how do you remove the sidewall skins, without removing the roof skin? Does the roof skin not bend over the wall skins? Thank you for the reply! I suppose we did take the skin off the top... we undid it around the top to take the rails and side skins off. We haven't lifted it fully off, though, and weren't planning on it. I've seen the mobiltec videos where the skins were lifted off and elevated with a pulley system. Should we lift them, and if so, is there a good way to do it? Thanks!
bigblue
1962 Shasta Airflye
Post by bigblue on Sept 28, 2020 17:28:57 GMT -8
I'm about to get to this point myself and I have a couple technical questions. I understand concept of the wrap, but doesn't moisture moving through fiberglass still condense on the inside of the wrap and trap it in the same place that the skins alone would? It seems that the rigid foam would then be more ideal since the moisture would be much less likely to reach cooler surfaces, no? I guess I'm just trying to wrap my head around what's the better option (see what I did there?). Also, regarding removing the side without the roof, I watched this guy do it before I find this forum. He made it look pretty easy. www.youtube.com/watch?v=U6YouK-PgmA
Post by John Palmer on Sept 28, 2020 20:04:39 GMT -8
I'm curious, how do you remove the sidewall skins, without removing the roof skin? Does the roof skin not bend over the wall skins? Thank you for the reply! I suppose we did take the skin off the top... we undid it around the top to take the rails and side skins off. We haven't lifted it fully off, though, and weren't planning on it. I've seen the mobiltec videos where the skins were lifted off and elevated with a pulley system. Should we lift them, and if so, is there a good way to do it? Thanks! There's lots of ideas on how to do different operations. You need to use what ever works for you best. I'm a old guy and like to be efficient and to do the best job the easiest way. No matter how you choose to remove the roof skin YOU HAVE TO STRAIGHTEN THE BENT OVER EDGES FIRST. You might ask why? Because if you move the roof skin around even just a little it will very easily tear at the bent over at edge. There's no possible way to rebuild the wall framing edge wood rot and end up with exactly the same radius, same width, same height walls. The right and the left wall frames did not match each other when they were built sixty plus years ago. So.........when you put the old roof skin back on after the trailer is rebuilt, you will be VERY LIKELY BENDING THE EDGE IN A DIFFERENT LOCATION by a 1/8" or so. It's even better if the metal bends in a slightly different location so it does not crack. Do yourself a favor, try your very best to rebuild the trailer width about 1/4" to 1/2" narrower than original, if your plans are to reuse the original roof skin. If by chance the rebuilt trailer ends up 1/4" wider, and you are using a original roof skin, you are screwed! Here's how this 70 plus year old guy removes a roof skin by himself in a driveway without any fancy pulleys. Pull all of the staples/nails/screws first. Straighten all of the edges with a piece of 2 by 4, and a plastic faced hammer. If I still have a little bend left, I use a "flat faced" auto body hammer and a auto body dolly and hammer it flat. Do not use a crown faced hammer because it will stretch the aluminum. Be careful remember that aluminum is very soft and over working it will stretch it, which creates more issues for you down the road during the remounting. Just work it flat and stop. Roll up the roof skin into a roll about 12" to 18" in diameter. Have two Irwin clamps ready. I use the kind with the flat pads and clamp the edge on each side with one clamp. Crawl up your ladder, balance the rolled roof skin on your shoulder and walk down the ladder. It goes back on in the reverse order. It's not heavy, but it can be bulky if you do not tightly roll it and clamp it. To store it while your working on the framing, just stand it on end and place a motorcycle strap around it so it does not get knocked over. John
Post by John Palmer on Sept 28, 2020 20:48:14 GMT -8
I'm about to get to this point myself and I have a couple technical questions. I understand concept of the wrap, but doesn't moisture moving through fiberglass still condense on the inside of the wrap and trap it in the same place that the skins alone would? It seems that the rigid foam would then be more ideal since the moisture would be much less likely to reach cooler surfaces, no? I guess I'm just trying to wrap my head around what's the better option (see what I did there?). Also, regarding removing the side without the roof, I watched this guy do it before I find this forum. He made it look pretty easy. www.youtube.com/watch?v=U6YouK-PgmACondensation occurs when warm moist air contacts something cold. The house wrap (or the Styrofoam) does not get cold like cold aluminum does, so no condensations occurs. All the seams are taped, so the interior air does not freely travel to the aluminum skins. I like the ridged foam sheet for an entirely different reason besides the benefit of insulation and better control of condensation. It "fills in" the space void between the wall studs and roof rafters. This helps support the thin .030" aluminum skins. When you push your hand against a solid foam filled wall it does not flex in like a fiberglass, or a bubble foam insulated trailer. The foam is cheap, and easy to install. It's widely available (or can be ordered delivered) at the big box stores. I like to use the 3/4" thick size. One layer does the front/back/and ceiling. Two layers do the walls on my 1 1/2 thick walls. (note, I do not build 3/4" walls, ever). Thanks for the humor........I was very impressed on how he removed an entire frame wall with out ever removing the roof metal or roof framing. I would not think it was possible, but I'm proven wrong again. It will be interesting on how he puts it back together without it blowing apart going down the freeway. It's a GUTTED nightmare! For anyone new to the trailer hobby, the above YouTube video shows just about every wrong way to do anything close to rebuilding a "stick and tin" style constructed trailer. Look at the video, then read the many posts on VTT, buy Viks ebook, and watch Larry's videos "before you pick up the Saw-z-all", or buy any trailer. John
Post by vikx on Sept 28, 2020 22:09:04 GMT -8
You can also "FLOAT" the roof and yes, it should be. The process is placing boards under the roof and sliding it to the side 8" or so to do edge wood inspection and repairs. If the wood isn't in too bad of shape, this is an easy way to fix things. Tie the roof down well when done for the day.
I've also slid the roof metal off and rolled it. Depends on the situation.
Pay attention to John: straighten the roof edges before moving the metal!
kanolan
Post by kanolan on Sept 30, 2020 11:21:40 GMT -8
This is sort-of what we did, except we only took off the aluminum. We don't plan to replace anything more than we need to!
kanolan
Post by kanolan on Nov 3, 2020 2:49:58 GMT -8
Thank you, everyone! We ended up floating the roof as Vik suggested with 2 by fours running under it. It worked out great and we were able to slide vapor barrier between.
Post by wisconsinjoe on Nov 4, 2020 6:48:43 GMT -8
Part of the reason rigid foam is so good is that it is closed cell. In cold weather (when you tend to keep windows closed to keep warm) frost condensation happens at the place where warm moist air hits a surface that is 32 degrees. So if inside is warm and moist and 70 degrees and outside is cold and 25 degrees, the place that is 32 degrees is somewhere in the middle of that foam where water vapor can't get to. As long as you have a fairly tight fit between the wood framing, and if you tape the seams, that water is not going to reach the cold aluminum, where it would eventually drip down to lay on wood framing.
Conversely, fiberglass will allow that moisture to condense somewhere in the middle of it, thus wetting it, leading to all sorts of problems. So, if you are going to use fiberglass, the vapor barrier should be used directly inside the interior wall skin. At least up here in the midwest.
But the other great reason for foam is that it solidly supports the aluminum exterior skin, as John mentions.
