Post by wisconsinjoe on Sept 18, 2020 9:50:14 GMT -8
Okay, got one more in me. Here is my solution to store sheets of plywood and other sheet goods in a minimal space. 20200913_123746 by Joe Mirenna, on Flickr It is basically a frame of 2x material that is angled back against a wall so leaning sheets are fully supported to prevent bowing. But it has two cool features. 20200912_140615 by Joe Mirenna, on Flickr The first is a slanted base. Because of this, as sheets are added, gravity moves each one tightly against the next so all sheets are angled and flat against the supporting frame. The second feature is the addition of two strong ropes that can clip into eye hooks embedded in the base. By adding in some slack, you can tilt the entire pile toward you safely as you sort and search your stash of plywood. Here is close-up of that base: 20200912_140825 by Joe Mirenna, on Flickr
Post by vikx on Sept 18, 2020 11:24:29 GMT -8
Love this idea! Thanks for posting all your tips and tricks, Joe.
