1964aloha
1964 Aloha 13 foot travel trail
Post by 1964aloha on Jul 1, 2020 11:55:54 GMT -8
Hi new member here I have a 1964 Aloha 13 foot i am putting a shower in the closet , small but better then no bathroom at all . I made a fiberglass shower pan for it and it is installed , my question is what can i use for the shower wall panels .I would like some input from someone who`s used the materials and ideas out there ? I need something light and easy to work with , one of the walls has a bend to it . Shower wall panel will have to be flexible on that wall .
Post by vikx on Jul 1, 2020 21:17:47 GMT -8
Home Depot sells shower panels, some sort of flexible plastic or?
1964aloha
Post by 1964aloha on Jul 2, 2020 7:24:38 GMT -8
Hi Thanks for the reply I have seen these panels i was hopping to find something else with a pattern on it but i may have to use them , to me they look a little commercial but the idea is good thanks G W
ekimnamniets
Post by ekimnamniets on Jul 2, 2020 10:14:33 GMT -8
I think the material you're thinking of is F.R.P. (fiberglass reinforced panel). Have you considered making a stencil and creating your own design? Wouldn't be that difficult, and it would something YOU wanted to look at!
1964aloha
Post by 1964aloha on Jul 2, 2020 11:38:33 GMT -8
That`s a good idea ! I was thinking like maybe a border around the top, but your right a stencil would simplify it . "Thanks for the input" G W
Post by Hamlet on Jul 4, 2020 6:35:43 GMT -8
When we did a shower/potty room in Hamlet’s (ham style Compact) large closet, we just used several coats of marine spar varnish on the walls and door and sealed the edges to the shower pan with flexible caulking. It has worked flawlessly for ten years.
1964aloha
Post by 1964aloha on Jul 4, 2020 9:21:19 GMT -8
Hey thanks for the reply! Well i must admit never thought of that, so what about the the corners of the walls where they meet did you add some martial to it before you put the varnish on ? . In the corners of the walls in my trailer it has a plastic round bead "Thanks much appreciated" G W
1964aloha
Post by 1964aloha on Jul 5, 2020 18:02:47 GMT -8
Hi well thinking of putting a roof top Air Conditioner on my 1964 Aloha 13 foot wondering if any one has done that? , will it support the wight ? I was wonder if they make a small Air Conditioner that would work ? I would appreciate your input Thanks ! G W
Post by danrhodes on Jul 5, 2020 20:23:17 GMT -8
Vintage camper framing cannot support a rooftop AC. Those that do it properly use steel supports to reinforce the framing in the AC area. There are a lot of other creative solutions here including in the closet, under the bunk and slide out solutions.
1964aloha
Post by 1964aloha on Jul 6, 2020 7:32:49 GMT -8
Thanks for the reply ! appreciate your input Thanks ! G W
aries
Post by aries on Jul 7, 2020 11:06:09 GMT -8
Welcome aboard,very few alohas I can find here,let alone any with bathrooms.Pondered on the idea of installing one,but opted to keep closet.Send a few pics when able,curious to see your ideas?
1964aloha
Post by 1964aloha on Jul 7, 2020 15:49:39 GMT -8
Thank`s Aries for the Welcome ! GW
1964aloha
Post by 1964aloha on Jul 7, 2020 16:18:22 GMT -8
I think the material you're thinking of is F.R.P. (fiberglass reinforced panel). Have you considered making a stencil and creating your own design? Wouldn't be that difficult, and it would something YOU wanted to look at! Hi I pick up the F.R.P. (fiberglass reinforced panel) today so i believe it will work out ,as far as the air conditioners i am going to go with a portable air conditioners but for now i want to finish the bathroom . I`ll try to load some pictures did not work last time i tried .
1964aloha
Post by 1964aloha on Jul 19, 2020 7:12:25 GMT -8
My wheel wells have L - angle 1/2" x 1" soft bendale aluminum , does any one out there know where i can get some bendale aluminum molding. when pulling off the old molding it got really bent up and stretched they used big and long nails G W
1964aloha
Post by 1964aloha on Mar 13, 2021 11:57:31 GMT -8
Hi My aloha has one battery mounted on the toung I have two propane tanks mounted on it so there`s alot of weight on the toung so are there a battery that i could mount inside that would be safe from battery fumes battery fumes charging ? G W
