Post by coastcommander on May 19, 2020 13:36:22 GMT -8
Hello! I need to replace the small upper window in the top bunk of our '68 Aristocrat Land-Commander and I'm having trouble figuring out where to start. It's not like any of the other Jalousie windows, and almost looks like more of a vent? I see these little windows(?) on a lot of the Aristocrat models, but can't seem to find what they're called or any replacements with the same dimensions. I'm including some photos. The people we bought it from currently have the window stuffed up with cardboard—would love to get it sealed up properly asap! Any ideas? I appreciate the help!
Post by vikx on May 19, 2020 19:48:15 GMT -8
It's a small Hehr window. They are mounted either vertically or horizontally. Yours looks to be 19 1/2 inches?
Also, you can put a new seal and glass in there without replacing the whole window. (if the guts are still there and they appear to be from the photo)
Post by nccamper on May 20, 2020 5:32:00 GMT -8
Shasta used that type of window in the Airflyte. See below.
Two things to consider, as vivkx suggested, take it out and try to straighten it and replace the seal around the window and the back-seal.
You can buy the seals at the source in this thread: They will help you get the right seals.
Or you can replace the window. I've gotten some excellent used parts from a member who sells from his extensive collection.
Trailertrasher1@gmail.com
