Post by tmerrifield on May 10, 2020 11:06:27 GMT -8
Hello All,
I’m new to the forum and am looking for some guidance. We recently purchased what I believe is a ‘62, ‘63 or ‘64 Airflyte but we can’t figure out what year it is as it had no title.
The VIN is "C5 S14838". Ross, do you know?
Thanks!!!
Tim
Post by nccamper on May 11, 2020 4:26:33 GMT -8
Welcome!
Ross hasn't been on in a while. We're hoping he's doing well.
Post by tmerrifield on May 12, 2020 10:53:55 GMT -8
Post by Ten on May 12, 2020 17:11:33 GMT -8
Check the underside of the sink. It has the cast iron sink in it and it usually will have a manufacture date stamped on it. It may be a bit tough to find, as it is almost always on the back side of the sink. This will give you an approximation, even if not perfectly accurate.
Post by nccamper on May 13, 2020 4:40:09 GMT -8
Welcome!
I think it's a 61 or 62.
Ten had an excellent suggestion about the date on the sink. Also, if it has the original mirror it may be dated on the back.
Post by tmerrifield on May 13, 2020 18:24:12 GMT -8
Thanks all, I’m settling on either a ‘61 or ‘62 but the sink doesn’t have any legible numbers and there is no mirror.
It looks like the only way is to look at the VIN database, is there someone that has access to that?
Thanks!!!
Post by vikx on May 13, 2020 21:57:04 GMT -8
The only way to figure the year is to go thru the data base and compare your numbers with a similar trailer.In other words, if you find an Airflyte with a slightly lower number and another with a little higher, your year will be revealed. Ross is no longer logging on here. If you come close, please post what you've found as it will help everybody.
