68corsair
1968 Corsair
Post by 68corsair on Apr 27, 2020 19:54:29 GMT -8
I have a 1968 corsair air with an aluminum framed awning/shield. I would like to take it apart to polish it and replace the yellow fiberglass panels. Unfortunately the aluminum corners are crimped. Any help would be greatly appreciated. I did a search, but maybe I'm not using the correct name for this part. My awning search just turned up a bunch of fabric discussions.
Post by vikx on Apr 27, 2020 21:46:27 GMT -8
If you're replacing the fiberglass, you might be able to carefully multitool the crimps, then replace with some sort of good looking L bracket. Most were screwed and you might be able to do that too to put it back together.
68corsair
1968 Corsair
Post by 68corsair on Apr 28, 2020 5:55:05 GMT -8
If you're replacing the fiberglass, you might be able to carefully multitool the crimps, then replace with some sort of good looking L bracket. Most were screwed and you might be able to do that too to put it back together. Thanks Vikx. I guess I could drill out the crimps and then later replace them with screws.
Post by wisconsinjoe on May 3, 2020 6:29:30 GMT -8
I faced crimps that were put in place to hold the rubber rain shields on my Herr windows. I total mess. I tried drilling them out from the side, but still it was hard to remove the old damaged seals. I hate any building strategy that is not reversible.
Post by Teachndad on May 7, 2020 4:20:55 GMT -8
I have a 1968 corsair air with an aluminum framed awning/shield. I would like to take it apart to polish it and replace the yellow fiberglass panels. Unfortunately the aluminum corners are crimped. Any help would be greatly appreciated. I did a search, but maybe I'm not using the correct name for this part. My awning search just turned up a bunch of fabric discussions. Hi, 68Corsair, Glad to see you asking questions. The thing that covers the front window is called a rock guard or a road guard. On the forum, I have seen both terms used. Maybe that will help in your search. I thought I remember someone who had taken one apart. I can't find it, right now, though. Rod
