Post by Teachndad on Apr 2, 2020 16:34:31 GMT -8
Hi Friends, Completing the finishing touches on my Hehr Jalousie window. I need confirmation on the length of the D seal as well as the length of the side pile weather stripping. In the picture below, you can see the end of the D seal is where my gloved finger is pointing. I will assume the D seal is too short and probably shrunk over time. If you look about 1” in the direction of the camera, you will see the side pile weather stripping sticking out. I can’t remember if it stuck out on purpose so thus giving it a tab to grab with a pair of pliers for removal or replacement or I started to pull it out and did it later. I have already purchased the side pile weather stripping and I have the D seal. So, when installing the new D seal and side pile weather stripping: 1. Do I leave a tab sticking out on the side pile weather stripping as seen in the image? 2. If I do, then do I have D Seal butt up against the tab or cut off the tab so I can run the D seal all the way to the end of the mounting groove? Not sure if that’s clear? Thanks, Rod
Post by vikx on Apr 2, 2020 20:26:49 GMT -8
The pile strip I bought from VTS did not fit my jalousies. Also, the rubber bottom "bulb" did not fit the groove. I tediously trimmed it to fit but don't want to go there again. So be very sure the seals will fit before starting.
I would run the D seal the length of the groove.
Getnold
1957 Westerner Pony Express
Post by Getnold on Apr 4, 2020 15:06:10 GMT -8
The pile strip I bought from VTS did not fit my jalousies. Also, the rubber bottom "bulb" did not fit the groove. I tediously trimmed it to fit but don't want to go there again. So be very sure the seals will fit before starting. I would run the D seal the length of the groove. Same here Vik! I had to trim the "hair" with some small scissors and soap the D seal and yank it in the groove to make it fit. Took two of us and lots of cussing. VTG seals on the other hand...no problem.
Getnold
Post by Getnold on Apr 4, 2020 15:08:18 GMT -8
Hi Rob, Larry (mobiltec) has a video series on his website showing how to rebuild this window. I think all of the answers to your questions will be there.
WhitneyK
'67 Shasta Compact
Post by WhitneyK on Apr 5, 2020 6:38:23 GMT -8
Post by Teachndad on Apr 6, 2020 20:45:24 GMT -8
Hi Friends,
I did end up cutting the tabs from the side pile weather stripping after the new one was inserted.So, the D-Seal goes all the way across to the ends of the groove. BTW, it helps a little to have the glass out when you install the side pile weather stripping. The rewatch of Larry's video helped.
