johnd
1958 Boles Aero Zenith
Post by johnd on Sept 30, 2019 5:05:26 GMT -8
Just picked up a Boles Aero Zenith and the cook top and oven are Brown (Princess) and the Better Half wants it Turquoise, what paint do you folks recommend and are there any good tutorials available?
Thanks in advance for the help!
John
Post by kirkadie on Sept 30, 2019 7:47:14 GMT -8
Talk to the counter man (person) at an auto paint store, betcha they can help.
Post by danrhodes on Sept 30, 2019 8:12:22 GMT -8
Just from seeing others attempt this on facebook, I'd say that painting is not likely to be successful. You'd probably spend the same amount of money just buying a turquoise stove from someone parting out an old trailer and you'll end up with much less frustration. I don't know if there is a high temp paint that will properly adhere to old porcelain.
kathleenc
Post by kathleenc on Sept 30, 2019 13:16:03 GMT -8
several people had the oven door and top re-porcelained.
johnd
Post by johnd on Sept 30, 2019 14:06:41 GMT -8
several people had the oven door and top re-porcelained. Where would one take it to get that done? Thanks for all the input and help! John
Post by youngbloodhawk on Oct 2, 2019 4:01:28 GMT -8
Watched the flyte camp folks on tv this past weekend where they powder coated door and top. Even the gas manifold though obviously it was a different color/grey. Thought they would have gone porcelain but guess they know what works on high end resto
stevefd
1965 Shasta Compact
Post by stevefd on Oct 2, 2019 5:44:11 GMT -8
I believe someone mentioned good results on a facebook post I came across about a week or so ago, regarding Independence porcelain enamel. I came across custom ceramics in another blog, too. You may try to do a google search for porcelain enameling near me and see if you get any results. www.ipe-porcelain.com/www.customceramic.com/index.htm
Post by vikx on Oct 3, 2019 18:19:03 GMT -8
Is Flyte Camp still on the Travel Channel?
Post by youngbloodhawk on Oct 4, 2019 3:12:19 GMT -8
Is Flyte Camp still on the Travel Channel? 165 on dish. Cmt I think
johnd
Post by johnd on Oct 4, 2019 4:07:07 GMT -8
I believe someone mentioned good results on a facebook post I came across about a week or so ago, regarding Independence porcelain enamel. I came across custom ceramics in another blog, too. You may try to do a google search for porcelain enameling near me and see if you get any results. www.ipe-porcelain.com/www.customceramic.com/index.htmI have sent a couple of emails to Custom Ceramic and have yet to hear back from him, tried to leave a voice mail message but the inbox is full. I will give ipe a try. Thanks! John
Post by carlosfanning on Oct 13, 2019 21:40:52 GMT -8
There's an aqua stove and sink combo on facebook right now for $200. You'll be in for more than that trying to re-porcelain your existing one. Hello, everyone, I am Carlos Fanning and new over here. Just lurking around and got this to open with you all. This is amazing deals. I like the aqua color.
maidie
Post by maidie on Feb 2, 2021 7:22:23 GMT -8
My local stove repair man suggested Stove Bright . It comes in a can for high temp. Colors too.
erin
Post by erin on Mar 14, 2021 8:13:00 GMT -8
My local stove repair man suggested Stove Bright . It comes in a can for high temp. Colors too. Stove Brite specifically states it is not compatible with the grease and oil from food, application recommended is for the exterior of out door fire pits. Please read the specs before you use.
Post by 64shastaand68bandit on Mar 14, 2021 21:39:07 GMT -8
 I just had 2 stove panels and my sink re-porcelain/enameled at Gigi Hollydale’s Appliances in South Gate Ca. Each piece was $65. I dropped off and picked up but they do shipping. I forgot my grates initially and brought them back last week. I had the best conversation with Claude and Alex and they walked me through the whole process. 1. They put the pieces in the furnace at 500 to bake off all the oil and debris. 2. Then the pieces get sandblasted to bare metal. 3. The pieces are the sprayed with liquid paint and back to the furnace to remove the moisture. That process leaves just paint dust. 4. The last process is back to the furnace at 1500 to bake and the result in enamel/porcelain finish. flic.kr/s/aHsmV8Mzzi
Teachndad
1955 Rod and Reel
Post by Teachndad on Mar 26, 2021 5:07:07 GMT -8
Hi Friends,
That's a lot of work for just $65 a piece. Actually sounds like a good deal for what you get. Interesting to learn the process.
I have added Gigi's as a resource. Thanks, I am in So Cal, too.
Thanks.
