57heaven
Post by 57heaven on Jun 12, 2022 16:44:02 GMT -8
Does anyone know of a source for the concave style welt above or something close?
Post by Teachndad on Jun 14, 2022 4:25:05 GMT -8
Hi, Have you tried www.vintagetrailergaskets.com/ ? Contact info is on the home page. Robert answers the phone and returns emails quickly. Maybe try an internet search using "vinyl cove molding". Cheers, Rod
57heaven
Post by 57heaven on Jun 14, 2022 4:55:34 GMT -8
No luck at vintage trailer gaskets. He said just do some Google searching as well. So that is what you believe it is called, vinyl cove molding? Thanks
Post by Teachndad on Jun 14, 2022 6:52:06 GMT -8
No luck at vintage trailer gaskets. He said just do some Google searching as well. So that is what you believe it is called, vinyl cove molding? Thanks Honestly, I didn't know what it was called. I took the term "vinyl cove molding" from Larry's post on the previous page. It seemed like a good search parameter to use. Larry has been in construction and trailers for a long time and I figured his terminology would be a good place to start. Rod
Post by vikx on Jun 15, 2022 12:04:30 GMT -8
Cove molding is still available but most of it is quite a bit wider. You might look for wood or metal molding. I've seen pretty narrow in metal.
WhitneyK
'67 Shasta Compact
Post by WhitneyK on Jul 3, 2022 7:42:59 GMT -8
Search for "cove welt", "cove welting", or "cove gimp". Found some on that jungle website... Whitney
57heaven
Post by 57heaven on Jul 5, 2022 10:29:27 GMT -8
Finally having some restoration work done on the Pathfinder. The walls do have factory insulation in them that is not in horrible shape so I'm looking for opinions on whether to reuse it or the person doing the work recommended using a high density 250 foam board. he said he can reuse the original insulation if I choose to. Just my decision. I like to keep things as original as possible within reason.
Post by vikx on Jul 5, 2022 11:45:51 GMT -8
Foam board.
57heaven
Post by 57heaven on Jul 12, 2022 5:52:33 GMT -8
Looking for opinions. I was told that the refrigerator is not original to the camper because it sits quite a bit higher than the top of the counter?
Post by vikx on Jul 12, 2022 11:08:08 GMT -8
I would have to see the fridge before passing judgement. Photos??
57heaven
Post by 57heaven on Jul 12, 2022 16:50:31 GMT -8
There is a picture earlier in this thread.
Post by danrhodes on Jul 13, 2022 14:06:56 GMT -8
Post by Teachndad on Jul 14, 2022 4:43:01 GMT -8
Looking for opinions. I was told that the refrigerator is not original to the camper because it sits quite a bit higher than the top of the counter? This should help.
That may be the original stove. I know it sits in front of the back splash, but where else would the stove go. Is that stove part of the fridge assembly as a unit? Also, is it a 3- way stove or just electric? Cheers,
57heaven
Post by 57heaven on Jul 14, 2022 8:00:43 GMT -8
The stove is propane.
57heaven
Post by 57heaven on Jul 14, 2022 8:03:07 GMT -8
The person doing some restoration work for me just thinks that the stove / fridge is not original to the camper because it sits so high above the countertop height. He thinks the burners on the stove would sit at about the same height as the top of the counter.
