Post by Teachndad on Jul 15, 2019 6:24:18 GMT -8
Hi Friends, This is the summer I spent in Window Hell... Am I having fun, yet? I can't do much else as I am recuperating from some surgery. Much of the glass on all my Hehr push out windows appears to have some sort of residue on them. At an angle when looking at the glare, it looks almost like over spray from paint spray. In cleaning the windows, I have removed the glass, washed off with soap and water and then went over with a wet soap filled Brillo pad. I have tried a razor blade to carefully scrape the surface and I still can't get it off. I have tried Lime Away which did nothing thinking it was hard water deposits. Anyone have any other ideas? I decided, if I have to, I am going to buy all new glass. My dog already broke one and that was a $20 replacement. It bugs me too much if I can't get this residue off the glass. I really like clean glass. BTW I only have one Jalousie window and that glass does not have the residue on it, it's just sort of yellowed. You can see it when you stack the glass sections on one another. Thanks, Rod
lila
Post by lila on Jul 15, 2019 11:00:11 GMT -8
Hi Rod Have you tried remov? silicone cleaner. I first learned of it from Larry. We use it all the time to get silicone off. website is removcanada.com You can also buy it on amazon and probably alot cheaper for you in the U.S. Lila
Post by Teachndad on Jul 16, 2019 5:18:00 GMT -8
lila
Post by lila on Jul 18, 2019 8:25:25 GMT -8
Hi Rod No I didn't answer on your other thread. The Remov stuff though i have used it on paint tape residue, silicone and butyl tape residue. works well on them. Wonder if you could try Wiedman glass stove cleaner. I use it on glass top stove, microwave front, patio windows. Put it on, scrub it, then dry with clean cloth. Lila
PT
Post by PT on Jul 18, 2019 17:59:43 GMT -8
Post by Teachndad on Jul 19, 2019 4:52:10 GMT -8
Dude, That Rocks! In reading the old thread, I got to echo, "Yep, that's pretty much me." My window glass doesn't quite look that bad though, but your pix look seriously "fogged". What did you use to scrub the A-Maz on to the glass? Ordering today. Thanks, Rod
PT
Post by PT on Jul 19, 2019 10:59:59 GMT -8
You can use the scrubber side of a sponge (the plastic kind). I moistened the sponge to help spread the AMAZ more easily on the glass. It takes some decent scrubbing pressure to get it done. Don't let the stuff dry out when you're working it into the glass. After it drys it rubs off like dry auto polish. If the first go-round doesn't get it all off just repeat and it will be crystal clear after a while.
Post by Teachndad on Jul 31, 2019 21:53:10 GMT -8
Hi Friends,
I didn't have the same positive results as PT. Your results will vary, LOL.
I bought the A-Maz as a set with a sponge through HD. I tried it a few times, scrubbed with pressure, but forgot to wet the sponge prior to scrubbing. I tried one time with applying too much and then with just enough to get a dried coating on top after scrubbing. I scrubbed vigorously following each application.
The result was that the pitting or whatever I see was still there. When I placed the window up to the the light to see the glare, I could see scratch swirls on the glass. I only scrubbed one half of the glass, so you could see the swirl scratches in the glare covering only half the glass.
I might try it again with a pre-dampened sponge. The alternative is just to buy new glass for all the windows. Not necessarily a bad thing as it can save a shoulder that was operated on 3 years ago from becoming re-injured. I have to ask myself: How much is the risk of injury worth to me to save $150?
Cheers,
roadtripper
Post by roadtripper on Aug 1, 2019 19:12:24 GMT -8
Many years ago I rebuilt some beveled glass with zink came windows that had been in my grandpas wood shop for ever. They had decades of overspray cabinet finish on them. I soaked the glass pieces in muriatic acid and water and they came out like new with no effort.
