Post by Teachndad on Jul 13, 2019 6:27:03 GMT -8
Hi Friends, How do I remove the screen material from this window? It’s on the back of a 4 pane jalousie window from a 1957 Westerner. I can’t tell if it’s using a spline to keep the screen inside the frame or wire? I am worried I might bend part of the screen assembly rendering it useless later. This is a Hehr Jalousie 4 J30 window. The screen material isn't the thick typical galvanized steel mesh that is seen on all the rest of the Hehr awning windows. It seems to be a thinner aluminum mesh. Thanks, Rod The two corners that are pictured at the top of the image are pretty much identical on all four corners. Is it spline or wire or both?
