Post by 72roadrnnr on May 30, 2019 12:37:51 GMT -8
Hi, I am fixing up a '72 Roadrunner and want to clean up and reinstall the windows. Does anyone know what this insert trim around the windows is and where I can get it? It seems to have a separate corner piece. Last owner siliconed all over so i want to clean up and reinstall each leaky window and replace this trim. Mine looks like this one: www.swvca.com/wpimages/wp8cb91431_05.jpgIts the black vinyl part around the white metal window. Much appreciated, 72roadrnnr
Post by vikx on May 30, 2019 20:51:18 GMT -8
Welcome 72 Roadrunner. There are a few companies that sell gaskets. You'll need a profile of the actual gasket if you can get one. If the gaskets are in OK condition, not sure I would replace them if the windows aren't leaking. Sometimes new ones aren't available.
Post by mobiltec on May 31, 2019 10:05:38 GMT -8
I can't tell anything by the photo. Way too far away. Not sure what gaskets you are talking about. Not even sure those are original/trailer windows.
Teachndad
1955 Rod and Reel
Post by Teachndad on Jun 15, 2019 11:50:02 GMT -8
Hi Friends,
I was convinced that those windows were not original - For a while.
Now I am not so sure.
I did a search on. 72 RR travel trailer.
Scroll down to the year 1972 and you will find two trailers with those similar(?) windows.
Curious.
I know that doesn't answer the OP's question, I was just looking for confirmation that these were original or not.
Cheers, Rod
