kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Oct 26, 2018 16:49:04 GMT -8
Ok- so I am running a 7 pin plug to a j-box under the trailer. From there- wires go to back for brakes, etc. I will then be taking the marker light wires from back lights over the top to the front marker lights ( I have 3 above front window and one on each side in the front). Struggling with how to run this marker light wire over the top- can i just lay it over roof beams ( taped in place to keep it in place)? There is no way I want to drill holes though every roof member to get to the front... but how else to get there? I am using Relectix insulation on the top- so can I tape wiring across roof members, covered with insulation and vapor barrier? HELP!! Thanks Kathy
n2hcky
1967 Serro Scotty Hilander
Post by n2hcky on Oct 26, 2018 17:44:45 GMT -8
I will have my junction box just under the front of the floor. I will just run another running light wire from box....up one side for first light across top for next 3 then over to other light on side. They don't have to be on the same wire as the ones at the rear.....just off the same terminal/circuit in the junction box.
Post by vikx on Oct 26, 2018 17:48:57 GMT -8
I drill holes thru the rafters to prevent damage.
datac
1957 Cardinal
Post by datac on Oct 27, 2018 23:11:57 GMT -8
Drill the holes.
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Oct 28, 2018 11:05:20 GMT -8
I did Thanks all ! Kathy
