Gary
1967 Aristocrat "Kini"
1967 Aristocrat LoLiner ST
Post by Gary on Nov 22, 2013 15:08:17 GMT -8
Soup, there aren't actually any cuts on the window since it's a flat surface. In that situation, you do get to bash out the lumps, but they end up flat eventually.
Post by mobiltec on Nov 22, 2013 15:13:07 GMT -8
Oh man this is all good stuff. Thanks for all of it. I should be driving around with my dog videoing YOU people instead of breaking my back videoing me making mistakes. HEY! That might not be a bad idea. A road trip tour with a good camera and you guys doing all the work. Hmmmm....
Post by bigbill on Nov 22, 2013 22:19:04 GMT -8
Gary I wasn't bashing your window work, that works well in there. I was using it as an example as what not to allow when doing a front or rear curve area do to the metal stretching it causes and you can't afford any stretch there at all. In a flat straight area it doesn't matter much how a person folds it over.
supermerle
No matter where you go, there you are.
1964 Shasta 1500
Post by supermerle on Dec 2, 2013 14:12:36 GMT -8
If you go to a HVAC store they sell a tool caled a crimper and it works like the harbor freight tool but its a hand tool that likes plyer's. They use it to put Duct work in. it has three blades on one side and two blades on the other side that forms the metal in a "W" shape and will help you make the curve without cutting the metal. it shrenks the metal. I'll try to find a picture and show every body. look these up Klein Tools 5-Blade Crimper
Post by bigbill on Dec 2, 2013 19:49:27 GMT -8
The tool he is talking about creates the end of a stove pipe so that it slides inside the next one. It would help to make a bend if properly used. They also used to make one that rolled along the metal something like a can opener that made the same crimps.
supermerle
1964 Shasta 1500
Post by supermerle on Dec 3, 2013 5:43:29 GMT -8
What happens is it shrinks the metal which is what you need to make the curve. Over on the Garage Journel their is a guy who go by MP&C and he shows you how to make these tools instead of buying them. I've never seen anything like this guy when it comes to metal work. When he replaces rusted out metal the panelis perfect and he he doesn't even use bondo.
Post by mobiltec on Dec 3, 2013 23:15:52 GMT -8
I would have to see a video of one of these tools in use or something...
