kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Jun 11, 2018 18:23:00 GMT -8
This is from my back window on my 63 Shasta 16 SC. The piece on the left has the spring, and the piece on the right has been repaired so I might try to find a new one. I know I am missing the lever that connects them together. However, the small piece in the middle- do I need that? And where does it go if I do ? Confused :} Thanks IMG_3509 by kathy, on Flickr
Post by vikx on Jun 11, 2018 22:05:08 GMT -8
Kaffi, please take a photo further back so we can see the whole window. I've seen both in Hehr windows...
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Jun 18, 2018 10:49:58 GMT -8
Kaffi, please take a photo further back so we can see the whole window. I've seen both in Hehr windows... Ok- getting back to this. Here is the window- the parts have been taken off. It goes in the back of my camper. measures around 30" X 15". Am I only missing the lever? IMG_3561 by kathy, on Flickr IMG_3560 by kathy, on Flickr
Post by mobiltec on Jun 18, 2018 11:55:12 GMT -8
Yep. That's all you're missing. If you give the measurements of the window panel and some photos to Chris (Trailertrasher) I'm sure he can find a lever for you.
Post by vikx on Jun 18, 2018 19:00:46 GMT -8
I'm confused; now there's a 3rd piece? I have a manual in the shop that lists several Hehr windows. Will take a look tomorrow.
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Jun 18, 2018 19:17:55 GMT -8
I'm confused; now there's a 3rd piece? I have a manual in the shop that lists several Hehr windows. Will take a look tomorrow. Oh boy ...Actually the medium length piece in the middle goes on the back of the one with the spring. I just took it apart to clean. I am wondering where does the very little piece go? It was not attached to anything. Sorry to confuse !
Post by vikx on Jun 18, 2018 19:19:26 GMT -8
I'll have to see if there's any info in the brochure. Not sure on that little piece. I use the other windows for a model...
Post by mobiltec on Jun 18, 2018 20:28:01 GMT -8
Oh I didn't even see that little one sitting there. Don't remember seeing one of those in the mix. Also the braces in that U bracket are not original. Is the U bracket broken or did someone think they should put those there for strength?
CorvettCrzy
'58 Corvette, '64 Franklin
Post by CorvettCrzy on Jun 18, 2018 20:33:31 GMT -8
Neither of my Hehr windows had that extra little piece. The rest of yours is made the same as mine.
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Jun 19, 2018 17:27:56 GMT -8
Oh I didn't even see that little one sitting there. Don't remember seeing one of those in the mix. Also the braces in that U bracket are not original. Is the U bracket broken or did someone think they should put those there for strength? Ok-I think the little piece is not for this window- and will try and ask trailer trasher for a lever. Thanks all! Larry- I think the bracket did break and they fixed it. It seems strong- so if I cant find a replacement I will keep it for now. Thanks once again !!!
