kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Jun 8, 2018 17:09:46 GMT -8
I took apart my gas light to repaint- and I cannot figure out how the ceramic nose fits with the metal 'spring'. I am assuming the metal spring holds the mantel in- but can someone show me how the end piece sits? It seems wonky the way I put it back together. Thanks :} IMG_3415 by kathy, on Flickr
Post by vikx on Jun 8, 2018 21:17:11 GMT -8
Haven't seen the spring before. Are you sure the on/off lever is in the right place?
Post by mel on Jun 9, 2018 3:02:39 GMT -8
I dont know but this is what the one in my Compact looked like
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Jun 9, 2018 14:25:17 GMT -8
Haven't seen the spring before. Are you sure the on/off lever is in the right place? Hi Do you mean the black dial? I didn't take it off. does it not look right to you?
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Jun 9, 2018 14:26:43 GMT -8
I dont know but this is what the one in my Compact looked like Yeah- that's the same one! Ok- that picture helps. Do you know how the mantle goes on? Over the spring? Just have not seen one together before this. THanks K
