kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Apr 23, 2018 14:29:20 GMT -8
Rebuilding my bench seats. Question- since the bench seat bases were not in one piece when I got this camper- I want to make sure I do this right. Am I correct in assuming a piece of plywood went over the support slats ( 3 - not in yet) and then the bench cushions sat on that? Or do the cushions just sit right on the horizontal supports? The cushion have been redone and are beautiful- I just don't know if there was something under them. Thanks IMG_2927 by kathy, on Flickr
Post by vikx on Apr 23, 2018 20:12:45 GMT -8
There is usually a little 'lip' of ply in the front of the dinette to hold a thin piece of ply in place. I often add a slat or two for more support. I also drill a finger hole to lift the ply. In other words, the slats sit on a support board that allows the ply to sit slightly below the rim of the dinette face. Hope this makes sense.
Post by Ten on Apr 23, 2018 20:36:30 GMT -8
These dinette benches would have originally had the innerspring framed seats, rather than just foam cushions. The framing supplied the support so there were no slats. I'll see if I can dig up some of my photos from the Airflyte.
Post by mobiltec on Apr 24, 2018 13:08:24 GMT -8
If you are going to use cushions instead of framed innerspringed seats I can show you what I did with the Super Shasta.... Got my feet in the foot photo contest! There is a ledger on the wall as well with a couple of supports going from the bottom of it to the floor.
