coldham
1954 Terry
Post by coldham on Nov 11, 2013 22:05:58 GMT -8
What type of wood are you all using when replacing rotten wall framing? Im sure this has been discussed but I couldn't find it. I feel like I've read about people using poplar and pine. I'm leaning toward using pine (I think they call it "white board pine" at HD) but I want to make sure that's not a mistake.
Thanks!
Post by vikx on Nov 11, 2013 23:26:25 GMT -8
I buy reasonably priced wood, without a lot of knots. I've bought special poplar and wasn't impressed with the difference. You won't "make a mistake". Use normal framing lumber, check for warp and splits.
Post by cowcharge on Nov 12, 2013 6:54:26 GMT -8
Yup, regular ol' 2Xs ripped to size.
61 Shasta
Post by 61 Shasta on Nov 12, 2013 10:43:02 GMT -8
I used regular old pine 1x's. I generally purchased 1x12's in 8 or 10 foot lengths. I could then rip them to whatever width I needed for any specific application. You will find you have a lot less waste doing something like this and it will save money in the overall project. As Vikx states, make sure they are not full of knots, especially loose ones. You will never (I don't think) find a board completely free of knots but just make sure they are clear as possible from what you have to select from.
Post by cowcharge on Nov 12, 2013 12:17:58 GMT -8
Right, 1Xs for the older ones. I keep forgetting lol.
61 Shasta
Post by 61 Shasta on Nov 12, 2013 12:52:20 GMT -8
Seems I remember that name from the old forum? "coldham"
Post by mobiltec on Nov 12, 2013 21:32:16 GMT -8
White wood. It doesn't start to bow as easily as pine or fir when the weather changes or the sun comes out. Strong wood but not too hard. Available at my favorite store,,,,, Home Depot.... Oh wait... Second favorite. I do wish Harbor Freight sold lumber.
coldham
1954 Terry
Post by coldham on Nov 12, 2013 22:10:38 GMT -8
Thanks everybody. I think the white board is what I was thinking. Maybe it isn't pine.
61 shasta I'm new to this site and I wasn't ever on the old site. I wasn't very creative with the name "coldham" so I probably ended up recycling someone else's.
kenman
Post by kenman on Jan 5, 2014 6:00:37 GMT -8
I was once told by my local builders supply man to never use pressure treated lumber next to (attached to) metal as it would cause corrosion to the metal. I see where it seems none of you use PT lumber...is this right?
Post by bigbill on Jan 5, 2014 6:25:20 GMT -8
Yes most people are of the opinion that it will cause alum to corrode in direct contact. I have seen it done in pole barns but not sure of the results. I don't use it anyway because of the cancer causing chemicals involved with much of it.
kenman
Post by kenman on Jan 5, 2014 6:32:27 GMT -8
OK...thanks.. I put some in the floor of one years ago. It is gone now though.
Post by SusieQ on Jan 5, 2014 9:20:26 GMT -8
Years ago, it would have been a bad thing to do, PT and aluminum. The process has changed, and while it does still contain copper, it is less corrosive now. If the lumber has a tag that says not to use it in contact with aluminum definitely heed the warning. I'm not suggesting the use of it, but thought I'd share from Lowe's site: www.lowes.com/cd_top+choice+severe+weather+lumber_1312549273_Fastener Performance and Aluminum Compatibility
Lowe’s Standard Decking and Top Choice Water Repellent Treated wood are less corrosive to fasteners. Our above-ground framing and decking products are approved for direct contact with aluminum hardware, spindles and flashings, even in continuously wet applications. The new preservative system used in our above-ground lumber doesn't require a barrier of protection between aluminum flashings and the treated wood.If you do choose to use a PT wood, check the recommendations for the particular brand you are considering. And yes, I've used it at the bottom of my framing over the wheel well. So time will tell. Not too worried about my skins at this point, but would not want the fasteners to turn loose.
Post by bigbill on Jan 5, 2014 12:17:28 GMT -8
The new pt wood with no lead is better they say. If there is a problem what you will see is the skin will dissolve right around the fastener head where it is clamped to the wood. If you see that happening it is to late.
Post by vikx on Jan 5, 2014 20:43:13 GMT -8
I've used PT as well, before I knew any better. I dried it for two years before using it, not sure if that will help or not. So far, no complaints.
Hey, the nature of our addiction is to improve as we go. Mistakes teach. Anyone can learn and improve! Every trailer I figure out something more, better or cooler. There isn't just one way to build a trailer, either. Lots of different methods give us new ideas...
Pet Peeve: Know it alls who refuse to learn. If we don't grow as we go, there's no improvement...
Post by bigbill on Jan 6, 2014 2:14:02 GMT -8
In todays world things change everyday.
