kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Feb 26, 2018 16:10:30 GMT -8
Hello all. Few questions: Is this electrical set up original to my 1963 Shasta 16SC? IMG_1986 by kathy, on Flickr Also- the wiring of my trailer ( to lights, marker lights, etc) actually looks good. My brother was suggesting that I not rewire- as he saw no need (except maybe the breaker box above). Thoughts on NOT replacing wiring to lights if wiring looks good? IMG_1973 by kathy, on Flickr IMG_1973 by kathy, on Flickr THanks K
charliemyers
Post by charliemyers on Feb 26, 2018 17:06:26 GMT -8
I can’t say if the breaker box is original or not. Whatever you do with the breaker box, definitely DEFINITELY keep those bare wires (ground wires) isolated from the white wires (neutrals) just like it appears they already are.
For the trailer light wiring, if it’s still in good condition and if you don’t need to move any of it when replacing wall framing, I’d agree with your brother.
Post by vikx on Feb 26, 2018 22:29:02 GMT -8
I agree with Charlie, your wiring looks very good. If it ain't broke, don't fix it...
That said, you need to think about any upgrades you want to do. Add a circuit? You'll need a new inlet and 30 amp (10ga Romex) to the breaker box. That way, you can operate the lights on the original circuit and the 2nd can be for a microwave or other kitchen area appliances. Add and outdoor outlet too.
Most of it can be done thru the cabinets, but is easier when you have the skins lifted/off.
Let us know what you want to do and we'll go from there.
Post by mobiltec on Feb 27, 2018 6:18:53 GMT -8
Yep. All looks good to me. You can replace the box with a two breaker type for 30 amps of service but as Vikx said, you will need a new inlet for the extra power. We'll be talking about systems tonight in class.
Post by nccamper on Feb 27, 2018 10:21:21 GMT -8
I'm surprised your wiring is grounded. My 62 Forester and 63 Shasta were not.
Everything said above makes perfect sense but I'll add that if the skin was off, and you want high demand items like a microwave or AC, I'd rewire everything. While you're at it and the skin is off I'd wire for 12 volt. A couple of charge ports and a light or two are mighty nice off the grid.
(This is why my campers never come in on budget.)
Post by vikx on Feb 28, 2018 21:22:25 GMT -8
Kaffi, I'm thinking... always dangerous.
Looking at your photos again, the wing nutted wires should all be tucked neatly in the box. They are hanging out in the open and could be vulnerable to damage. Where are they going and what is that greyish cut out? Wiring should always be enclosed and protected, so this will need to be changed. Don't panic. It's not difficult.
We need a few more photos. Tell us what your plans are. Do you want to use electrical appliances? Need an outside outlet?
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Mar 2, 2018 7:23:35 GMT -8
Kaffi, I'm thinking... always dangerous. Looking at your photos again, the wing nutted wires should all be tucked neatly in the box. They are hanging out in the open and could be vulnerable to damage. Where are they going and what is that greyish cut out? Wiring should always be enclosed and protected, so this will need to be changed. Don't panic. It's not difficult. We need a few more photos. Tell us what your plans are. Do you want to use electrical appliances? Need an outside outlet? Hi I really have no idea about electric. I think I will put off planning for that until I get my rear floor in, framing done, panels shellacked and installed. I will surely be asking tons of questions when I get to this stage...for now I will put it on hold until then My mind can't handle thinking about it at the moment- overload! Hahaha Really tho- I am doing great....just want to be able to focus on that system when the time is right. Thanks - you have been an incredible help so far! K
Post by vikx on Mar 2, 2018 11:03:06 GMT -8
If you want to add wiring, it's much easier with the walls open...
Post by Ten on Mar 2, 2018 17:55:38 GMT -8
@vikx , If I may, the photo above is a wall sconce light removed from the box and tipped toward the camera. Note the outline of the bunk bracket to the left. The wires would have pulled from the box and the backside of the lamp. The grey cutout is the back side of the light. kaffi311 , Vikx is absolutely right, the wiring changes or upgrades are lots easier when things are opened up. But, don't sweat the planning too much. Most of the planning actually comes to you when you are doing something else anyway. You will start to see yourself using the camper and envisioning how you want it to work for you as you go along. Then it becomes easy to put the systems together so they will work for you.
Post by vikx on Mar 2, 2018 21:34:51 GMT -8
Thank you Ten!!! I was so confused as to what that grey thing was.... LOL
