kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Feb 21, 2018 12:20:58 GMT -8
I took a good look at my curbside wheel well today- and it's in good shape except for the flanges that are nailed to the underside of the floor: IMG_1932 by kathy, on Flickr Is there any way to fix / strengthen that without having to replace the whole thing? I am not taking cabinets out-so getting to the wheel well looks impossible without taking out the tall cabinet. Any ideas would be so appreciated. I do have a friend that welds...if that helps THanks Kathy
Post by nccamper on Feb 21, 2018 15:10:39 GMT -8
I added sheet metal, riveted together with epoxy, to add a few inches to one of my Shasta campers. It's not IMO a high stress area so I think you'll be fine.
Post by vikx on Feb 21, 2018 20:47:46 GMT -8
They are fine, just wrinkled a bit, Kaffi. See if you can flatten the metal in order to reattach. I would think add the floor, then a sturdy brace and you should be able to tap on it from below. It isn't super important to have them perfect, nobody will be studying your wheel well flanges. LOL. Also, be sure to use putty tape between the flange and floor to seal. You can use caulk when done, but it's usually not necessary.
Post by vikx on Feb 22, 2018 11:21:16 GMT -8
One more thing: with the flange under the floor be SURE to attach the wells securely. I add 1 by backers to screw into. They go on the floor at the well edges.
I bolted the flanges in the Loliner after some severe sagging. (street wall bulge is common in Loliners)
