kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Feb 16, 2018 18:51:42 GMT -8
I am getting ahead of myself for sure- as I am just beginning to replace the rotted framing on my camper. However, just thinking of the future a little. Re: Heaters- this is the one I have in my 65 Shasta SC. IMG_0727 by kathy, on Flickr thumb_IMG_0392_1024 by kathy, on Flickr I just took apart that closet to replace rotted wood framing. I am wondering if the wave-3 I am reading about and interested in can be put back in this spot? Just want to be aware for when I rebuild that closet if I need to plan for a different heater size ( I definitely want to get a new one). Thanks!
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Feb 16, 2018 18:58:18 GMT -8
BTW- I am so proud of myself that I have accomplished this myself this week: Sanded and painted framing with rust inhibitor (spray paint) and fence paint from TS, installed 2X4 supports in frame for seams in new plywood subfloor ( especially around cabinets), installed my first piece of flooring, and started on the curbside framing. Love all the help I get from this site and from Mobiltec!!! IMG_1827 by kathy, on Flickr IMG_1835 by kathy, on Flickr IMG_1847 by kathy, on Flickr
Post by nccamper on Feb 16, 2018 19:36:48 GMT -8
"I am wondering if the wave-3 I am reading about and interested in can be put back in this spot?" I did just that. I made a 3/4 base to cover the old heater space and attached the Wave3 before attaching the heater to the existing gas line. Before: After:
Post by Ten on Feb 16, 2018 20:33:33 GMT -8
nccamper , Was the original vented through the roof, or out the side wall? How did you deal with the vent that won't be used?
Post by nccamper on Feb 17, 2018 5:44:49 GMT -8
nccamper , Was the original vented through the roof, or out the side wall? How did you deal with the vent that won't be used? I replaced the roof which eliminated the roof vent. Although I considered reinstalling just the vent when I thought the roof could be saved. The original roof vent is just behind the door:
Post by mobiltec on Mar 5, 2018 15:28:09 GMT -8
If you use a Wave or any other catalytic heater like the Wave, please make sure to install a C02 detector... I don't like those things. You MUST keep them covered when not in use to prevent dust from collecting on them. Plus it's going to create moisture condensation inside the trailer which will freeze your windows shut if you are in freezing temps. The only heaters that don't do all this are Vented heaters.
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Mar 5, 2018 16:17:11 GMT -8
If you use a Wave or any other catalytic heater like the Wave, please make sure to install a C02 detector... I don't like those things. You MUST keep them covered when not in use to prevent dust from collecting on them. Plus it's going to create moisture condensation inside the trailer which will freeze your windows shut if you are in freezing temps. The only heaters that don't do all this are Vented heaters. Do you have a heater that you can recommend? Just exploring options. Thanks K
Post by mobiltec on Mar 5, 2018 16:44:26 GMT -8
I have a trailer with a small heater like the one you have in it. I cleaned it all out and it works fine and has a thermostat. The only heaters I can fully trust vent outside of the trailer. Either out the side or out the top. Atwood makes a forced air heater for $300 and I put that one in the 18 foot Super Shasta which has a 16 foot box. Might be a little overkill but then again it depends on how much winter camping you plan on doing and how severe the temps get. I'm not very well versed in heaters as I spent most of my life in Southern California.
Post by vikx on Mar 5, 2018 22:07:40 GMT -8
Larry's right, vented heaters are the way to go if yours works.
BUTT: the only passive replacement is a marine heater to the tune of 1300 dollars. There may be some cheaper, but hard to find.
The Waves work very well in milder climes. The colder it gets, the more they sweat the windows. I lived with a 6 for 5 years and never had the CO detector warning. They are extremely safe if you follow the directions on installation and use.
Many vintage trailers can't support a "furnace" because they require 12 volts to run. Off grid, they deplete the battery very quickly. They are also very greedy on propane.
Hard to make a choice, but if you have a working passive heater, KEEP IT.
