Post by jtrobinson on Dec 14, 2017 6:33:46 GMT -8
Anyone ever install an outdoor receptacle on a 64 Shasta?
Post by vikx on Dec 14, 2017 22:53:16 GMT -8
Welcome Jtrobinson.
I install an outdoor receptacle on all my trailers. The 57 Shasta Deluxe is the newest one but very similar to a 64.
I will probably move this thread to our 110 electrical section in a couple of days.
Post by Ross on Dec 15, 2017 8:01:50 GMT -8
Welcome aboard! Like Vikx, I add exterior outlets on every camper. This was our last project, a 1966 Yellowstone and we placed the outlet under the dining window. We do try to use the older style BELL cover plates, when possible.
Post by Ten on Dec 15, 2017 10:34:55 GMT -8
I have not done anything with my '64 in a while, but did add one to the '70 when I was working on it. I added a line across the trailer from the breaker box to power a 12-V converter, and tapped off from that to add the outside box. I did mine a little differently.
Post by mobiltec on Dec 15, 2017 12:19:51 GMT -8
I prefer putting any outdoor outlet boxes underneath the trailer close to the wall because if you put it on the side of the trailer, even if it's "a waterproof" fixture, it's still just another place to leak. But most of my customers do not want to lay down on their backs to get to it. Not sure why because you always have to lay down on your back when setting up a trailer anyhow. There's always something you must do that requires it.
Post by mel on Dec 16, 2017 4:59:21 GMT -8
I put mine underneath on my Compact too.
Post by vikx on Dec 18, 2017 20:13:05 GMT -8
I tried to strip one a while back and it peeled. Ended up scruffing it with sandpaper and painting with Rusto Hammered silver.
Don't think the metal in these is very good quality and probably won't polish very well.
Deleted
Post by Deleted on Dec 18, 2017 20:27:37 GMT -8
These receptacle covers are likely die cast aluminum or "pot metal". You definitely can sand and polish these down to a bright finish, but it likely won't last long. Most folks would go to the step of plating this material if you wanted something polished and really long lasting. Otherwise, painting like Vikx suggested would work fine.
Deleted
Post by Deleted on Dec 18, 2017 20:31:17 GMT -8
By the way...Bell still makes these same covers today for everyday outdoor use. Not sure what might be "vintage" about the one you obtained?
Post by mobiltec on Dec 18, 2017 21:21:38 GMT -8
By the way...Bell still makes these same covers today for everyday outdoor use. Not sure what might be "vintage" about the one you obtained? LOL like toilet paper. They haven't changed in the last 50 years...
Post by ladywendolyn on Dec 18, 2017 21:56:35 GMT -8
By the way...Bell still makes these same covers today for everyday outdoor use. Not sure what might be "vintage" about the one you obtained? The only reason I know it is vintage is because it came in the original package which was mid century. I bought it off eBay. I would love to find one in shiny stainless or chrome. I’ll keep looking. At least I have this one as a back up.
Post by Ten on Dec 20, 2017 6:01:41 GMT -8
Lady W, Maybe you might want to try picking one up at the local lumber yard or hardware store,since they have basically been made the same way to resist outdoor conditions for many years. That way you could try some polishing techniques and see what happens without sacrificing your vintage one to find out.
I would recommend starting with a coarse steel wool and a dollop of elbow grease first, and see how that cuts the factory finish. More aggressive measures could be added if needed. If you have a rotary tool like a Dremel at your disposal, a fine wire brush attachment may work for trimming along the edges of the plug covers and the other fine areas that are hard to reach by hand. Finish polishing with a rub of Mothers Aluminum Wheel polish, clean the residue off well, and maybe try a couple coats of clear enamel paint. This is all only a guess but I may try this as well, for future reference.
Post by ladywendolyn on Dec 26, 2017 22:29:05 GMT -8
Thanks for the suggestion Ten I will try that.
