kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Nov 19, 2017 12:02:28 GMT -8
Black sealant gunk around tail lights...what is it? How to best get it off? Thanks Kathy
<a data-flickr-embed="true" href="https://www.flickr.com/photos/126814716@N02/24654384258/in/dateposted/" title="IMG_0508"><img src="https://farm5.staticflickr.com/4547/24654384258_59d71f7eb4_z.jpg" width="480" height="640" alt="IMG_0508"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/126814716@N02/38495132242/in/dateposted/" title="IMG_0507"><img src="https://farm5.staticflickr.com/4559/38495132242_31570fb5ae_z.jpg" width="480" height="640" alt="IMG_0507"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Post by Ten on Nov 21, 2017 6:45:31 GMT -8
I would start by attempting to remove the taillights. They are not original to the trailer, and it looks like someone cut holes to fit them into and then tried to seal them with something that came in a tube at the time it was done. If you can remove without bending up the edges of the holes, then you should be able to chip the sealant away more easily. If it can't be chipped away without damaging the skin, then I would try some different solvents to soften it up, starting with something like a paint thinner or denatured alcohol. If they do not work then move to something a little more potent. I have heard of others using gasoline, but I highly recommend something less volatile like diesel fuel. Protect your hands whatever you use, if you need to get that far. If it were me, I would consider a replacement for the lights. The originals are a bit difficult to find and may not cover the holes. There are a couple options to use a recessed light, or re-use the ones that are there if they clean up to your satisfaction. By the way, they would have to be removed anyway if you are removing the rear wall panel to get at the framing underneath. This is just one step in the many steps.
Post by mrmarty51 on Nov 21, 2017 11:47:13 GMT -8
My go to chemical for removing oil, grease or tar is charcoal lighter fuel, it is the exact same stuff as what Stoddard cleaning solvent is. I do not think that it would be too good at removing that type of caulking, probably scraping and wire brush will be the answer. Brake and Parts cleaner might be an option, it is usually harmless to wire insulation and other types of plastics, but a test area should be tried first to make sure. B&P cleaner will probably soften the paint, if a paint job is not included in the restoration, caution should be used when applying the B&P cleaner.
Post by Teachndad on Nov 24, 2017 8:10:35 GMT -8
Hi Friends,
It looks like Henry's roof sealant. Just a guess.
Maybe try a heat gun with a plastic putty knife. Just throwing ideas out there. No idea if it would work. Heat it with the low setting and see if it softens up first, then go with the higher setting. The plastic putty knife would be so you don't scratch our gouge the aluminum around the lamp holes.
cheers,
