sherrifriend
1967 Compact Shasta
Post by sherrifriend on Jul 15, 2017 4:39:50 GMT -8
I am working on my floor and subfloor and I have two questions:
#1 - Should my wall (which attaches to my wood framing) rest on the steel frame outriggers any?
#2 - What's the best way to check that the floor is square on the trailer frame?
aslmx
Post by aslmx on Jul 15, 2017 17:58:28 GMT -8
The wall does sit on the out riggers. If you are not replacing the skin I would try to rematch all the original measurements even if they are out of square. I have a 67 and my walls were an inch narrower in the front than the rear. I'm using the old skin so that's the way it's going back
Post by mrmarty51 on Jul 15, 2017 21:03:41 GMT -8
To check the floor for square: Measure criss cross, then shove the long measurement towards the short measurement. Anchor one end down so that it can not move when shoving on the other end. Repeat until both criss cross measurements are the same.
Post by vikx on Jul 15, 2017 21:20:26 GMT -8
Asimx is right, let the trailer tell you what to do..
Post by mrmarty51 on Jul 16, 2017 17:55:28 GMT -8
Asimx is right, let the trailer tell you what to do.. Thats the best way. I threw in the instructions for making a square floor so that if it come down tooit She would know how.
